Multiple servos with delay
Hi my friends, this is my first topic, but I already learned a lot from you guys.
I’m working o my first Arduino based project, I was going ok, but I got stuck with my servos.
The intention is:
  • Servos start on position 30
  • If you push the button once, the servos will come from position 30 to position 120.
  • If you push the same button the second time, the servos will come back to position 30.
  • The servos must turn slowly
  • The servos must turn one after the other (not all on the same time)
With the code below I got almost everything working, but:
  • On the void setup I can’t set the servos to keep on position 30
  • On void loop I can control the speed by delay(20), but I cant make them work one after the other, they go all on the same time.
I would appreciate so much if someone gets me a hint to move forward of this.
Thank you Very Much!
#include <Servo.h>
Servo servo1;
Servo servo2;
Servo servo3;
Servo servo4;
Servo servo5;
Servo servo6;
// Set digital pin numbers:
const int buttonPin = 13;  // The number of the Pushbutton pin
int buttonState = 0;  // Variable for reading the pushbutton status
int directionState = 0;  // Variable for reading direction of the servo
int pos = 30;  // Variable to store the servo position
  servo1.attach(14);  // attaches the servo on pin 8 to the servo object
  servo2.attach(15);
  servo3.attach(16);
  servo4.attach(17);
  servo5.attach(18);
  servo6.attach(19);
  pinMode(buttonPin, INPUT);  // initialize the pushbutton pin as an input
  // read the state of the pushbutton value:
  buttonState = digitalRead(buttonPin);
  if (directionState == 0) {
    //The button is pushed
    if (buttonState == HIGH) {
      directionState = 1;// The direction for the servo is clockwise
      // goes from 30 degrees to 120 degrees in steps of 1 degree
      for (pos = 30; pos < 120; pos = pos + 1)
        servo1.write(pos);  // tell servo to go to position in variable ‘pos’
        delay(10);  // waits 15ms for the servo to reach the position
        servo2.write(pos);  // tell servo to go to position in variable ‘pos’
        servo3.write(pos);  // tell servo to go to position in variable ‘pos’
        servo4.write(pos);  // tell servo to go to position in variable ‘pos’
        servo5.write(pos);  // tell servo to go to position in variable ‘pos’
        servo6.write(pos);  // tell servo to go to position in variable ‘pos’
  } else if (directionState == 1) {
    // The button is pushed
      directionState = 0;  // The direction for the servo is anti-clockwise
      // goes from 120 degrees to 30 degrees in steps of 1 degree
      for (pos = 120; pos >= 30; pos = pos-1)
In setup() you can do a servo.write(30) before you attach the servo object to a pin. That will cause the servo to move to 30 immediately.
You are stepping all of the servos in a single loop. To make them go in turn you need a separate loop for each servo.
Hi John, Thank you your extremely fast reply.
I have just fixed the initial position of all the servos, but I didn’t get how to create loops for each servo
Updated version with servo.write
#include <Servo.h>
Servo servo1;
Servo servo2;
Servo servo3;
Servo servo4;
Servo servo5;
Servo servo6;
int pos = 0;  // Variable to store the servo position
  servo2.attach(15);
  servo3.attach(16);
  servo4.attach(17);
  servo5.attach(18);
  servo6.attach(19);
servo1.write(30);
servo2.write(30);
servo3.write(30);
servo4.write(30);
servo5.write(30);
servo6.write(30);
Like this:
      for (pos = 30; pos < 120; pos = pos + 1) {
        servo1.write(pos);  // tell servo to go to position in variable 'pos'
        servo2.write(pos);  // tell servo to go to position in variable 'pos'
       servo3.write(pos);  // tell servo to go to position in variable 'pos'
        servo4.write(pos);  // tell servo to go to position in variable 'pos'
Do you see how that would sweep each one in turn rather than all at once.
See this http://forum.arduino.cc/index.php?topic=223286.0 and don't use delay
Mark
John,
Thank you once again, It worked.
For future references, here is the code and the VIDEO.
#include <Servo.h>
Servo servo1;
Servo servo2;
Servo servo3;
Servo servo4;
Servo servo5;
Servo servo6;
  servo2.attach(15);
  servo3.attach(16);
  servo4.attach(17);
  servo5.attach(18);
  servo6.attach(19);
  servo1.write(30);
  servo2.write(30);
  servo3.write(30);
  servo4.write(30);
  servo5.write(30);
  servo6.write(30);
        delay(25);  // waits 15ms for the servo to reach the position
      for (pos = 120; pos >= 30; pos = pos - 1)
Thank you
