Multiple Servos
I'm trying to get more than two servos to work. I read this page here: http://www.arduino.cc/playground/ComponentLib/Servo
Apparently that is very old since lib/targets/libraries folder does not even exist and it tells me to place the files there. Instead I put them in the hardware library Servo (replacing the old ones), but I get some error.
Is there any other way to control more than two servos?
It is possible to get that library working - you should be able to find some solutions searching the forum.
But there is a library here that supports 8 servos and is easier to use because it doesn't need you to constantly call a refresh method: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1230479947
And if you can wait a few days I am testing a new library that supports 8 servos (possibly 12) on a standard Arduino and 32 (possibly 48) an the new Arduino Mega :)
Also, you could use a chip such as the TLC5940; a PWM I/O expander that will allow you to control up to 16 servos on each chip with great accuracy. You can also daisy-chain them so it is theoretically possible to have infinite servos. But obviously this is not actually possible! There is a also a great library for this chip.
Could you say what error(s) you got?
I'd be interested in this as well, I'm currently playing around with the TLC5940, but I'm having a hard time getting reliable performance out of it, the servo (HS-422) won't turn as far to one side as it does to the other for instance, but this could very well be up to my newbieness.
/A
I really would be interested in that library. Thanks in advance.
There is beta code of the library supporting 12 servos on a standard Arduino (48 servos on a Mega) : http://www.arduino.cc/playground/uploads/Code/MegaServo.zip
And some information on its usage here: http://www.arduino.cc/playground/Code/MegaServo
Works great, thanks!
Now I just need to get some more servos :)
/A
