Here is a approach using two alternately triggered software timers to generate the interleaved pulses. I am simulating the zero cross interrupt with a timer interrupt output on pin 3. Jumper pin 3 to pin 2 which is the external interrupt pin.
I've scaled everything down by a factor of 10 to see reasonable serial output of the interleaved timing. The serial output looks reasonable but this wasn't tested with a scope.
EDIT 11:00 revise location of counter reset to fixa bug where case 7 not being actually entered
change startTimer variables to unsigned long
//https://github.com/PaulStoffregen/TimerOne/blob/master/TimerOne.h
#include <TimerOne.h> //to generate external interrupt model zero cross
const unsigned long interval = 5000;//pulse length high microseconds and initial delay from trigger
const unsigned long scaleFactor = 10;//slowing factor, replace with 1 for full speed
const unsigned long period = interval*scaleFactor;
byte timerACount = 0;
byte timerBCount = 0;
volatile boolean runTimerA = false;
volatile unsigned long startTimerA;
volatile boolean runTimerB = false;
volatile unsigned long startTimerB;
volatile boolean intTrigger = false;
byte pinStart = 4;//start number output pins for 6 pulses
//set pins 4,5,6,7,8,9 as output for 5ms pulses
for (byte i = 0; i <= 5; i++)
pinMode(pinStart + i, OUTPUT);
pinMode(2, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(2), pulseTrainTrigger, FALLING);
pinMode(3, OUTPUT);//timer trigger
Timer1.initialize(20000*scaleFactor);//every 200 ms scale factor 10
Timer1.attachInterrupt(trigger);
Serial.println(micros()/1000);
if (runTimerA ==true && (micros() - startTimerA >= period))
//enters 5ms after initial trigger
//enters at 0 and increments counts to 1,2,3,4,5,6,7
startTimerA += period;
timerACount++;
Serial.print('\t');
Serial.print("A");
Serial.print(timerACount);
Serial.print(" ");
// if (timerACount == 7)
// timerACount = 0;
// runTimerA = false;
switch (timerACount)
case 1://5ms after trigger turn on first output
digitalWrite(pinStart, HIGH);
case 2://10ms after trigger
digitalWrite(pinStart + 1, HIGH);
digitalWrite(pinStart, LOW);
case 3://15ms after trigger
digitalWrite(pinStart + 2, HIGH);
digitalWrite(pinStart + 1, LOW);
case 4://20 ms after trigger
digitalWrite(pinStart + 3, HIGH);
digitalWrite(pinStart + 2, LOW);
case 5://25ms after trigger
digitalWrite(pinStart + 4, HIGH);
digitalWrite(pinStart + 3, LOW);
case 6://30ms after trigger
digitalWrite(pinStart + 5, HIGH);
digitalWrite(pinStart + 4, LOW);
case 7://35 ms after trigger turn off last output
digitalWrite(pinStart + 5 , LOW);
timerACount = 0;
runTimerA = false;
if (runTimerB == true && (micros() - startTimerB >= period))
//enters at 0/increments counts to 1,2,3,4,5,6,7
startTimerB += period;
timerBCount++;
Serial.print('\t');
Serial.print('\t');
Serial.print("B");
Serial.print(timerBCount);
Serial.print(" ");
// if (timerBCount == 7)
// timerBCount = 0;
// runTimerB = false;
switch (timerBCount)
timerBCount = 0;
runTimerB = false;
if (intTrigger)
intTrigger = false;
Serial.println(millis());
//alternate timers with external interrupt trigger
void pulseTrainTrigger()
static byte triggerCount = 0;
if (triggerCount == 0)
startTimerA = micros();
runTimerA = true;
if (triggerCount == 1)
startTimerB = micros();
runTimerB = true;
triggerCount++;
if (triggerCount == 2)
triggerCount = 0;
//test trigger
//generate trigger pulse on pin 3 with Timer1 jumper pin 3 to pin 2
void trigger()
intTrigger = true;
digitalWrite(3, HIGH);
digitalWrite(3, LOW);
