Ya, all program work well if run individually. I used Servoandrelay program as base. Now i have successfully combined relay and servo program ( replaced case to if) but still facing difficulties to merge OAR and relay and servo.
I want if i would send ‘a’ via Bluetooth OBSTACLE AVOIDING FUNCTION should begin and should stop when i would send ‘A’.
I tried to put a new if statement and inserted OAR program (added other sketch elements also and they don’t share any pin). When i upload this code arduino doesn’t respond at all.
This is the code which work well and i wanted to add OAR in this.
#include <SoftwareSerial.h>
#include <Servo.h>
char val;
Servo myservo1, myservo2, myservo3, myservo4;
int bluetoothTx = 0;
int bluetoothRx = 1;
SoftwareSerial bluetooth(bluetoothTx, bluetoothRx);
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(7, OUTPUT);
pinMode(8, OUTPUT);
pinMode(12, OUTPUT);
myservo1.attach(5);
myservo2.attach(6);
myservo3.attach(10);
myservo4.attach(11);
//Setup usb serial connection to computer
//Setup Bluetooth serial connection to android
bluetooth.begin(9600);
Serial.println("It's me robot");
//Read from bluetooth and write to usb serial
if(bluetooth.available()>= 2 )
unsigned int servopos = bluetooth.read();
unsigned int servopos1 = bluetooth.read();
unsigned int realservo = (servopos1 *256) + servopos;
Serial.println(realservo);
if (realservo >= 1000 && realservo <1180){
int servo1 = realservo;
servo1 = map(servo1, 1000,1180,0,180);
myservo1.write(servo1);
digitalWrite(2, LOW);
digitalWrite(7, LOW);
digitalWrite(3, LOW);
digitalWrite(8, LOW);
digitalWrite(12, LOW);
Serial.println("servo 1 ON");
delay(20);
if (realservo >=2000 && realservo <2180){
int servo2 = realservo;
servo2 = map(servo2,2000,2180,0,180);
myservo2.write(servo2);
Serial.println("servo 2 On");
delay(20);
if (realservo >=3000 && realservo < 3180){
int servo3 = realservo;
servo3 = map(servo3, 3000, 3180,0,180);
myservo3.write(servo3);
Serial.println("servo 3 On");
delay(20);
if (realservo >=4000 && realservo < 4180){
int servo4 = realservo;
servo4 = map(servo4, 4000, 4180,0,180);
myservo4.write(servo4);
Serial.println("servo 4 On");
delay(20);
int appdata;
if( Serial.available() ) // if data is available to read
val = Serial.read(); // read it and store it in 'val'
if( val == 'f' ) // if 'a' was received led 2 is switched off
digitalWrite(2, HIGH);
digitalWrite(7, HIGH);
if( val == 'F' ) // if 'A' was received led 2 on
if( val == 'b' )
digitalWrite(3, HIGH);
digitalWrite(8, HIGH);
if( val == 'B' )
if( val == 'l' ) // if 'C' was received led 2 on for 1 second
if( val == 'L' ) // if 'D' was received led 3 on for 1 second
if( val == 'r' ) // if 'E' was received led 2 on for 5 seconds
if( val == 'R' ) // if 'F' was received led 3 on for 5 seconds
if( val == 'c' ) // if 'F' was received led 3 on for 5 seconds
digitalWrite(12, HIGH);
if( val == 'C' ) // if 'F' was received led 3 on for 5 seconds
