Multiple sketches
Hi, is it possible to upload multiple sketches, and cycle through them by htting that "reset'' button? h
ow is this done with the duemilanove?
thx
No, it isn't possible if you need to ask the question. Look at EEPROM storage and functions.
how is this done with the duemilanove?
It's not...
You could run some kind of interpreted program such as Bitlash and then change between them but not using the reset button ;)
Mowcius
You could combine all of the sketches into a single sketch and use the EEPROM to track which sub-sketch you are going to run next. Check and update the EEPROM after each reset.
