Multiple SPI control
I am having a weeny trouble with my SAMD21 board. I have got this starter kit (schematics) and I want to add some more sensors. They use SPI, so I programmed them. Since SAMD21 got the code it lag's everytime, when code reache's the sensor begin function. Please give me some advice, how to control both SPI's correctly and avoid lags.
*lags are total lags - SAMD21 do nothing after reaching the begin function.
*schematics: http://kit.sciencein.cz/wiki/images/b/be/MainBoard_v2.0_RevB_SCH.png
*sorry for mistakes in the code (it is long code cut to short)
*my code:
#include <Adafruit_BME280.h>  // include Adafruit BME280 library
  #include <Adafruit_INA219.h>  // include INA219
  #include <SD.h>          // include Arduino SD library
  #include "Open_Cansat_GPS.h"
  //include our new sensors
  #include "MQ131.h"
  #include <Wire.h>
  #include <SPI.h>
  #include "RFM69.h"       // include RFM69 library
  // Local
  #define PC_BAUDRATE       115200
  #define MS_DELAY    0  // Number of milliseconds between data sending and LED signalization
  #define LED_DELAY     100
  #define Serial SerialUSB
  RTCZero rtc;
  // RFM69
  #define NETWORKID       0        // Must be the same for all nodes (0 to 255)
  #define MYNODEID        1          // My node ID (0 to 255)
  #define TONODEID        2          // Destination node ID (0 to 254, 255 = broadcast)
  #define FREQUENCY       RF69_433MHZ   // Frequency set up
  #define FREQUENCYSPECIFIC 433000000  // Should be value in Hz, now 433 Mhz will be set
  #define CHIP_SELECT_PIN   43 //radio chip select
  #define INTERUP_PIN       9 //radio interrupt
  // BME280 SETTING
  #define BME280_ADDRESS_OPEN_CANSAT 0x77
  #define SEALEVELPRESSURE_HPA    1013.25
  //OZONE2CLICK
  const byte pinSS = 2; //cs pin
  const byte pinRDY = 12;
  const byte pinSCK = 13;
  const byte O2Pin = 10;
  #define DcPin 8
  // SD card
  #define sd_cs_pin 35 // set SD's chip select pin (according to the circuit)
  // create object 'rf69' from the library, which will
  // be used to access the library methods by a dot notation
  RFM69 radio(CHIP_SELECT_PIN, INTERUP_PIN, true);
  // define our own struct data type with variables; used to send data
  typedef struct
    int16_t messageId;
    uint16_t year;
    uint8_t month;
    uint8_t day;
    uint8_t hour;
    uint8_t minute;
    uint8_t sec;
    float longitude;
    float latitude;
    uint8_t num_of_satelites;
    float temperature;
    float pressure;
    float altitude;
    float humidity_bme280;
    float voltage_shunt;
    float voltage_bus;
    float current_mA;
    float voltage_load;
    int16_t rssi;
  } messageOut;
  messageOut cansatdata; //create the struct variable
  // create object 'bme' from the library, which will
  Adafruit_BME280 bme;
  // create object 'ina219' from the library with address 0x40
  // (according to the circuit, which will be used to access the
  // library methods by a dot notation
  Adafruit_INA219 ina219(0x40);
  // create object 'gps' from the library
  OpenCansatGPS gps;
  // SD card
  File file; // SD library variable
  // LEDS
  #define D13_led_pin 42  // D13 LED
  #define M_led_pin 36  // MLED
  // Local variables
  int idCounter = 1;
  bool isBmeOk = true;
  bool isSdOk = true;
  bool isRadioOk = true;
  bool isGpsConnected = true;
  // My variables
  float NH3Data;
  float COData;
  float NO2Data;
  float PPMO2;
  float PPBO2;
  float MGM3O2;
  float UGM3O2;
  float SSmoke1;
  float SSmoke2;
  float SSmoke3;
  float ESmoke1;
  float ESmoke2;
  float ESmoke3;
  int DataCounter = 0;
  void OZONE2CLICKCalibrate ()
  Serial.println("2");
    //MQ131.begin(pinSS, pinRDY, O2Pin, LOW_CONCENTRATION, 10000);  //(int _pinCS, int _pinRDY, int _pinPower, MQ131Model _model, int _RL)
    Serial.println("99");
    Serial.println("Calibration in progress...");
    MQ131.calibrate();
    Serial.println("Calibration done!");
    Serial.print("R0 = ");
    Serial.print(MQ131.getR0());
    Serial.println(" Ohms");
    Serial.print("Time to heat = ");
    Serial.print(MQ131.getTimeToRead());
    Serial.println(" s");
  void OZONE2CLICKMeasure ()
    Serial.println("Sampling...");
    MQ131.sample();
    Serial.print("Concentration O3 : ");
    PPMO2 = MQ131.getO3(PPM);
    Serial.print(PPMO2);
    Serial.println(" ppm");
    PPBO2 = MQ131.getO3(PPB);
    Serial.print(PPBO2);
    Serial.println(" ppb");
    MGM3O2 = MQ131.getO3(MG_M3);
    Serial.print(MGM3O2);
    Serial.println(" mg/m3");
    UGM3O2 = MQ131.getO3(UG_M3);
    Serial.print(UGM3O2);
    Serial.println(" ug/m3");
CANSAT_2.0_check.ino (25.4 KB)
If your code is too long to post, it's better to add it as an attachment, especially if you had to mangle it in order to post...
