Currently I am working on a project that incorporates four RFID-readers with the MFRC522-library, along with an EthernetShield, connected to an Arduino Mega.
The following behaviour is observed:
-Judging from serial feedback, all four RFID-readers are working correctly.
-The EthernetShield is working, but only when I disconnect the 3.3v to the RFID-readers. Otherwise I cannot even ping it.
Somehow a SS is not working correctly and there is some crosstalk... you would say.
But the strange thing is: Even if I only have the SCK connected to the RFID-readers (MOSI/MISO disconnected, so no MISO crosstalk), the EthernetShield will not work!
When I disconnect the 3.3v to the RFID-readers it works like a charm again!
So basicly it seem the RFID-readers are messing up the ICSP clocksignal, even though all four work properly.
Maybe somebody could help me figure this out, because this is hair-pullingly weirding me out
I don't use those, but it appears by the data sheet to that device, the max voltage applied to the input pins (MOSI and SCK) is the supply voltage +0.5v (3.8 volts in your case). The Mega is a 5 volt device.
But besides that, are you setting all SPI slave selects HIGH before starting any of these devices? Which pins are you using for the slave selects?
SurferTim:
The libraries take care of that themselves, so yes. But the strange thing is that it is not the MOSI/MISO that is giving trouble (I have disconnected them both, to no avail), but the SCK (If I disconnect that one the EthernetShield runs fine). Somehow the RFID-readers, when powered, manipulate the SCK-signal.
For the readers, I am using pins 14 through 21 for SDA/SS, and obviously 50/51/52 for MOSI/MISO/SCK.
Wessel:
No, they don't until you run all setup functions, then they take care of the slave selects. Initially the slave selects are floating. I recommend setting all slave selects to HIGH before starting any of those devices. If you start the ethernet shield without disabling the RFID device slave selects, it could cause problems.
