I also have an SD card module that uses SPI, so how could I still use both of these devices to display weather information from my station while still logging data? Thanks.
Each slave device has a separate Slave Select pin. For example the Ethernet Shield has both and Ethernet chip and an SD card slot. The Ethernet chip uses Pin 10 for Slave Select and the SD card slot uses Pin 4 for Slave Select. You can have as many SPI devices as you have spare I/O pins.
