Multiple SPI devices
I have an ST7920 128x64 LCD display in SPI mode, however I also need to use an SD card reader module. I tried to give them both different SS pins, but it seems the lcd doesn't care if SS is low or not, it always listens for the data. Am I doing something wrong here?
The ST7920 has a /CS pin. It should be active when you write to the display. And in-active when you stop writing.
Any respectable library will control the /CS pin correctly.
Which library? The Library Manager (or build report) will tell you.
What constructor? Have you specified the CS pin?
David.
david_prentice:
David.
I'm using the U8g2 library, here is the constructor:
U8G2_ST7920_128X64_1_HW_SPI u8g2(U8G2_R0, /* CS=/ 53, / reset=*/ 8);
The CS pin (labeled RS on the display) is low when I'm measuring it, but when I set it to high in the software it goes high, but the lcd doesn't care.
My apologies. There seem to be several reports on the Internet about CS being ignored.
I will try for myself later.
David.
Yes, the ST7920 still responds to SPI even when CS is in-active.
    const int SPI_CS = 7;
    const int OLED_CS = 10;
    digitalWrite(OLED_CS, LOW);  // CS is active-high for ST7920
    pinMode(SPI_CS, OUTPUT);
    digitalWrite(SPI_CS, LOW);   // most SPI devices are active-low
    for (int i = 0; i < 32; i++) SPI.transfer(0x55);
    digitalWrite(SPI_CS, HIGH);
Looking at the datasheet it implies that CS is important as an active-high “chip-select”. A Rising edge is used for for synchronising e.g. for sending the RW and RS bits.
From the internet discussions people try disabling SCK to the ST7920 when CS is in-active.
The easiest solution is to bit-bash software SPI for the ST7920 on different GPIO pins.
David.
