Multiple Stepper Motor Setup
Hey guys,
I am very new to the Arduino and microcontrollers in general. I am currently working on a project in which I am designing a GUI that will ultimately control 6 different bipolar stepper motors. We have come across an Arduino Duemilanove and I was hoping to be able to control these steppers with this device.
When looking for a driver configuration it seems as though there are systems that require only two pins on the microcontroller (direction and step signals) however I am still unsure if this will be possible with the number of pins on the Arduino.
If not is there another (hopefully affordable) method to do this?
TO control multiple steppers it would be easiest to have a separate drive for each stepper motor. A typical driver has 2 inputs - Step and Direction (and sometimes an Enable) This would mean each stepper would require 2 Arduino outputs (or if multiple motors move the same you could double up on some of them) Depending on your motors, you can find some simple small drivers or you can get some better commercial units.
If you want to build your own here is an idea of how to do it with Arduino tyoe tech… http://arduino.cc/forum/index.php/topic,84809.0.html This is something I hope to finish up on this winter - Uses an ATtiny2313 which accepts step and direction inputs and outputs the 4 phase signals to drive 4 MOSFETs to run a unipolar stepper. By using a driver the code in the main arduino gets simpler and mans you can actually do more.
