Multiple switching to multiple servo driver chips (via enable signal) using UNO
Folks
Please excuse my ignorance as I am keen to learn what I can and am struggling with code results.
Basically the idea is to take the Enable signal from my Rumba board which has one Z axis chip, link it through UNO Pin 2 and output it to three separate driver chips such that I would have 3 Z axis motors homing independently.
I have linked three limit switches to this as well as linking my LEDPIN 13 to activate each time any limit switch activates.
Results:
The code works for each servo and limit switch group, however if I have all servos operating then any limit switch activated pulls ALL servo Enables to LOW, they do not operate individually.
It would appear that I need to separate each servo / limit switch IF statments in some fashion to separate the resulting output.
Any guidance appreciated, this is my first sketch. I have researched all I can to understand further however now at a wall.
Thanks to all for assistance.
Z_Axis.ino (2.47 KB)
Why are you reading the limit switch pins twice and why use the pin numbers when you have given the pins names ?
Why the superfluous curly braces round blocks of code ?
