Hello all, one short question, it is possible to connect 4 TCS230 color sensors to the same pins? I mean the input pins (S0 S1 S2 and S3). I want to detect just the green color. Of course de output pin should be different.
The millis function is not pretty accurate. I try to detect the green color, but I want to continous check for 2 second if the condition is fulfill . Can you please help me with the code for RTC?
If you are checking for 2 seconds the millis() function will probably be accurate enough - it will be at most a few millisecond inaccurate. RTC minimum resolution is usually 1 second, so you can end up with an average error of 0.5 seconds.
Unfortunately the led won't keep the 2000 ms :-), sometimes the led turn off faster than 2 sec and sometimes keep still on, more than 3 second.
Where is the problem? for the moment just one color sensor is used and 2 laser receiver
#define sensor_laser_1 2 // pin 2 for laser sensor
#define sensor_laser_2 3 // pin 3 for laser sensor
#define S0 4 // frecventa scalare
#define S1 5 //frecventa scalare
#define S2 6 // HIGH pentru verde
#define S3 7 // HIGH pentru verde
#define sensorOut1 8 // out color module
#define sensorOut2 9 // citire culoare pe pinul 9
#define sensorOut3 10 // citire culoare pe pinul 10
#define act_pneu 11 // LED
int led_state = LOW; // definire piston stare initiala
unsigned long starTime = 0; // start arduino
unsigned long previousMillis = 0; // ultimul timp salvat
const long interval = 2000; // setare interval asteptare dupa 2 sec
pinMode(sensor_laser_1, INPUT);//define detect input pin
pinMode(sensor_laser_2, INPUT);//define detect input pin
pinMode(S0, OUTPUT);
pinMode(S1, OUTPUT);
digitalWrite(S0,HIGH);
digitalWrite(S1,LOW);
pinMode(S2, OUTPUT);
pinMode(S3, OUTPUT);
pinMode(sensorOut1, INPUT);
pinMode(sensorOut2, INPUT);
pinMode(sensorOut3, INPUT);
pinMode(act_pneu, OUTPUT);//define ACTION output pin
int laser1 = digitalRead(sensor_laser_1); // citire senzor laser intrare
int laser2 = digitalRead(sensor_laser_2); // citiare senzor laser iesire
int culoare1 = 0;
int culoare2 = 0;
int culoare3 = 0;
// Senzor culoare
digitalWrite(S2,HIGH);
digitalWrite(S3,HIGH);
culoare1 = pulseIn(sensorOut1, LOW);
culoare2 = pulseIn(sensorOut2, LOW);
culoare3 = pulseIn(sensorOut3, LOW);
if( laser1 == LOW || laser2 == LOW || culoare1 < 175)
led_state= HIGH; // cilindru pe ON
if ( currentMillis - previousMillis >interval)
led_state = LOW;
digitalWrite(act_pneu,led_state);
