Multiple Timers for each RFID input
I have a UHF RFID Reader and I wanted to add a timer for each UID Code (for entering, overstaying and exit in the vicinity). I am currently using Firebase as the Database. My code just occupies all the MAX_TIMERS, how do I solve this? Thanks.
#define MAX_TIMERS 10
FirebaseData fbdo;
FirebaseAuth auth;
FirebaseConfig config;
FirebaseJson json;
bool signupOK = false;
unsigned long sendDataPrevMillis = 0;
struct Timer{
  unsigned long startTime = 0;
  bool timerStarted = false;
  String storedCode = "";
Timer timers[MAX_TIMERS];
SoftwareSerial Serial2(RXD2, TXD2);
unsigned char data;
String code = "";
String uidPath = "/";
String device_id = "Entrance Gate 1";
int status;
void checkAccess(String code) {
  for (int i = 0; i < MAX_TIMERS; i++){
  if(!timers[i].timerStarted){
    timers[i].storedCode = code;
    if (Firebase.RTDB.getInt(&fbdo, uidPath + "/entryUsers/" + code)) {
      if (fbdo.intData() == 0) {
        json.add("time", String(timeClient.getFormattedTime()));
        json.add("id", device_id);
        json.add("uid", code);
        json.add("status", 1);
        Firebase.RTDB.setInt(&fbdo, "/entryUsers/" + code, 1);
        if(Firebase.RTDB.pushJSON(&fbdo, uidPath + "entryActivity" , &json)){
          Serial.println(fbdo.dataPath() + fbdo.pushName());
          timers[i].startTime = millis();
          timers[i].timerStarted = true;
          Serial.println(fbdo.errorReason());
      else if (fbdo.intData() == 1) {
        Firebase.RTDB.setInt(&fbdo, uidPath + "entryUsers/" + code, 0);
        json.add("status", 0);
        if (Firebase.RTDB.pushJSON(&fbdo, "/entryActivity", &json)) {
          timers[i].timerStarted = false;
      else if (fbdo.intData() == 3){
      else {
        Serial.println("FAILED");
        Serial.println("REASON: " + fbdo.errorReason());
void timerHandler(String storedCode){
    if(timers[i].timerStarted && millis() - timers[i].startTime >= 10000)
      Serial.println("Overstayed: " + timers[i].storedCode);
      Firebase.RTDB.setInt(&fbdo, uidPath + "entryUsers/" + timers[i].storedCode, 3);
      timers[i].startTime = 0;
void storeCode(){
  storedCode = code;
  while(Serial2.available() > 0) {                // Will Continue to read RFID
    data = Serial2.read();
    code = code + String(data, HEX);
  if (code.length() > 1) {                        // Since UHF stores single codes ex. (8f), so print in length
    Serial.println(code);
    checkAccess(code);
    storeCode();
  timerHandler(storedCode);
  code = "";
What happened when you increased this number?
