"multiple timers "
hello everybody :slight_smile: Im new in arduino world and before I write my question excuse me for my english.
I want to make 10 buttons to be inputs on arduino_one, every button is start and stop for its own
‚Äústopwatch‚ÄĚ and that arduino_one sends that time over rf 433 to arduino_two.
Arduino_two then receives that 10 times and compare its to threshold of 90sec if any time is biger then threshold then arduino_two print that time to LCD and print ‚Äúlap time‚ÄĚ to pc over serial and next to that time lap actual time meaning date and time.
As now:
I have no idea how to get ‚Äútimestamp‚ÄĚ
have only one ‚Äústopwatch‚ÄĚ
On serial i get time every second not the ‚Äúlap time‚ÄĚ start-stop time.
I have figured out lcd print of the time and if time is biger then threshold serial output is displayed.
I found a way to recognize 10 times over rf433 by changing bitlenght //
if (mySwitch.available()) {
if (( mySwitch.getReceivedBitlength()) == 32 ){""
code of sending arduino_one
#include <RCSwitch.h>
RCSwitch mySwitch = RCSwitch();
const int buttonPin = 9;    // the number of the pushbutton pin
const int ledPin = 13;      // the number of the LED pin
const int ledica = 11;
int ledState = HIGH;         // the current state of the output pin
int buttonState;             // the current reading from the input pin
int lastButtonState = LOW;// the previous reading from the input pin
unsigned long vrijeme = 0;
unsigned long lastDebounceTime = 0;  // the last time the output pin was toggled
unsigned long debounceDelay = 50;    // the debounce time; increase if the output flickers
 pinMode(buttonPin, INPUT);
 pinMode(ledPin, OUTPUT);
  pinMode(ledica, OUTPUT);
 // set initial LED state
 digitalWrite(ledPin, ledState);
 mySwitch.enableTransmit(10);
 // read the state of the switch into a local variable:
 int reading = digitalRead(buttonPin);
 // check to see if you just pressed the button
 // (i.e. the input went from LOW to HIGH),  and you've waited
 // long enough since the last press to ignore any noise:
 // If the switch changed, due to noise or pressing:
 if (reading != lastButtonState) {
   // reset the debouncing timer
   lastDebounceTime = millis();
 if ((millis() - lastDebounceTime) > debounceDelay) {
   // whatever the reading is at, it's been there for longer
   // than the debounce delay, so take it as the actual current state:
   // if the button state has changed:
   if (reading != buttonState) {
     buttonState = reading;
     // only toggle the LED if the new button state is HIGH
     if (buttonState == HIGH) {
       ledState = !ledState;
 // set the LED:
 // save the reading.  Next time through the loop,
 // it'll be the lastButtonState:
 vrijeme = (millis() - lastDebounceTime);
 lastButtonState = reading;
 vrijeme_loop();
seriski_ispis();
void vrijeme_loop(void)
   Serial.print(vrijeme/1000);
   (mySwitch.send((vrijeme/1000) ,32));
 void seriski_ispis(void)
    if (vrijeme/1000 > 10)
      digitalWrite(ledica, HIGH);
      else{
        digitalWrite(ledica, LOW);
code of reciver arduino_two
 Simple example for receiving
 http://code.google.com/p/rc-switch/
#include <LiquidCrystal.h>
LiquidCrystal lcd(7, 6, 5, 4, 3, 8);
unsigned long time=0;
const int led = 13;
 mySwitch.enableReceive(0);  // Receiver on inerrupt 0 => that is pin #2
 lcd.begin(16, 2);
 pinMode(13, OUTPUT);
read_data();
lcd_display();
void read_data(void)
unsigned long  time1 = mySwitch.getReceivedValue();
 time = time1;
if (time > 90){
 digitalWrite(led, HIGH);
   Serial.print("1600/2: ");
   Serial.print(time);
   Serial.print('\n');
 else{
   digitalWrite(led, LOW);
void lcd_display()
 lcd.setCursor(0, 0);
lcd.print("1600/2");
lcd.setCursor(0, 1);
 lcd.print("time pased");
lcd.print(time);
delay(300);
lcd.clear();
You can easily get time stamps by recording the value of millis() whenever a button is pressed. You could have an array of 10 start values and another array of 10 stop values. And maybe, for convenience, an array of 10 differences - i.e. the elapsed times.
Is it really necessary to use two Arduinos - that seems to add a lot of extra code.
However sending values from one to the other should be straightforward. Just iterate through the array and send the 10 values.
I imagine the examples in serial input basics can be adapted for receiving data on your system.
...R
Cross posted in programming questions
zmay2509: I have no idea how to get "timestamp"
I have no idea why you do cross-posting in this forum while the forum rules forbid cross-posting.
So perhaps you better first let a moderator merge your cross-postings into one thread. Then perhaps I will post a useful answer.
Cross-postings are just wasting time of moderators and time of people who are willing to help in this forum.
