Multiple TM1637 Seven segment displays, Will pay for Working code
Hello,
I have also posted this in part in the “displays” forum, moderators feel free to remove if you must.
Anyhow, I have a project that is time limited, I require having the registered pressure from 10 pressure transducers displayed on 10 TM1637 7 segment displays (one Pressure Transducer per one TM1637)
I have managed to get it to work singularly (one Pressure Transducer to show its pressure on one TM1637) but I cannot figure out how to take it to the next step and get another to work on the same arduino.
I am using the Arduino Mega and the library that I am using for the TM1637 is here: https://github.com/avishorp/TM1637
This is the code i have working:
#include <Arduino.h>
#include <TM1637Display.h>
#define CLK_1 22
#define DIO_1 26
TM1637Display
display(CLK_1, DIO_1);
   const int PressureTransducer_1 = A0;
   int PressureTransducerReading_1 = 0;
  display.setBrightness(0x0e);
  uint8_t data[] = { 0x0, 0x0, 0x0, 0x0 };
  int reading_1 = analogRead(PressureTransducer_1);
  float voltage = reading_1 * 5.0;
  voltage /= 1023.0;
  float PressurePSI_1 = (voltage - 0.5) * 10 ;
  display.showNumberDec(PressurePSI_1, true, 4,0);
  Serial.print(PressurePSI_1); Serial.println(" PSI");
As i said in the title, I am willing to pay for working code, nothing too ridiculous but tell me your price.
Thanks for any help you can give.
You should be able to do it by using a different pair of pins for each display and creating a separate TM1637 object for each display.
I'm sure I still have a handful of TM1637 displays on hand from a previous project. PM me if you need someone to write some demo code.
