I have a completed code, and I've read about the tone library and it seems like it would be a bit difficult for me to do what I'd like. Basically, I have a code for a hockey game already set up. So far, I haven't found out a way to play a short goal scoring tone with different frequencies and note lengths, only a buzz to indicate a goal being scored on a button press. After a button press and the corresponding tone ends, how could I add another tone say (buzzer, 1000, 500)? Thanks. Here is my code as is:
//+5 turns LED on
#define LEDon HIGH
#define LEDoff LOW
#define Buzzeron HIGH
#define Buzzeroff LOW
//+5 turns LED off
//#define LEDon LOW
//#define LEDoff HIGH
const unsigned long MyTime12 = 5*1000ul;
unsigned long Millis12;
const byte ledPin12 = 12;
const byte buttonPin2 = 2; //pushed = LOW
boolean flag12 = false;
unsigned long MyTime13;
unsigned long Millis13;
const byte ledPin13 = 13;
const byte buttonPin3 = 3; //pushed = LOW
boolean flag13 = false;
byte myState = 0;
const unsigned long MyTime11 = 5*1000ul;
unsigned long Millis11;
const byte ledPin11 = 11;
const byte buttonPin4 = 4; //pushed = LOW
boolean flag11 = false;
const byte buzzer = 8;
//variable for reading the pushbutton status
int buttonState = 0;
pinMode(ledPin12, OUTPUT);
//LED off at power on
digitalWrite(ledPin12, LEDoff);
pinMode(buttonPin2, INPUT_PULLUP);
pinMode(ledPin11, OUTPUT);
digitalWrite(ledPin11, LEDoff);
pinMode(buttonPin4, INPUT_PULLUP);
pinMode(ledPin13, OUTPUT);
//LED off at RESET
digitalWrite(ledPin13, LEDoff);
pinMode(buttonPin3, INPUT_PULLUP);
pinMode (buzzer, OUTPUT);
digitalWrite(buzzer, Buzzeroff);
// read the state of the push button value:
buttonState = digitalRead(buttonPin2);
//LOW is pressed
//if button pressed, start timing LED sequence
if (flag12 == false && buttonState == HIGH)
//enable timing
flag12 = true;
Millis12 = millis();
//LED on
digitalWrite(ledPin12, LEDon);
tone(buzzer, 400, 1500);
buttonState = digitalRead(buttonPin4);
//LOW is pressed
if (flag11 == false && buttonState == HIGH)
//enable timing
flag11 = true;
Millis11 = millis();
//LED on
digitalWrite(ledPin11, LEDon);
buttonState = digitalRead(buttonPin3);
//LOW is pushed
//if button pressed, start LED timing sequence
if (flag13 == false && buttonState == HIGH)
//enable timing
flag13 = true;
myState = 0;
Millis13 = millis();
MyTime13 = 5*1000UL; //LED OFF for 180 seconds 180*1000
//LED will remain OFF for 180 more seconds before it comes ON for 10 sec
//Time to toggle LED?
if(flag12 == true && millis() - Millis12 >= MyTime12)
{ //toggle ledPin12
digitalWrite(ledPin12, !digitalRead(ledPin12));
flag12 = false;
if(flag11 == true && millis() - Millis11 >= MyTime11)
{ //toggle ledPin11
digitalWrite(ledPin11, !digitalRead(ledPin11));
flag11 = false;
if(flag13 == true && millis() - Millis13 >= MyTime13)
//get ready for next iteration
Millis13 += MyTime13;
switch(myState)
case 0:
digitalWrite(ledPin13, LEDon);
myState = 1;
MyTime13 = 10*1000UL; //LED ON for 10 seconds
tone(buzzer, 300, 1500);
case 1:
//we are now finished with this button press
flag13 = false;
}//End of switch
} //END of loop()
