Hello,
I'm new in this forum and this is my first post but i'm a little experienced with using Arduino boards.
I'm designing a system that uses multiple Ultrasonic distance measurement sensors (HC-SR04), each sensor is working fine and accurate when i'm testing them alone. The problem is when i run them together, the echo signal of one of the sensors is not accurate (nearly %40 less than the actual distance of the obstacle).
My questions are:
1 - Are the sensors generating the same signal frequency?
2 - Are they receiving each other's echo signal or each one receives its own echo?
Thank you for the help.
