multiple Voltage sensors on Arduino
Dear fellows,
This is my fisrt post.... not from lack of reading posts, but needed some sort of confirmation from you the seniors.... :slight_smile:
I've different type of industrial sensors, mainly photo electrics proximity sensors....
they are using different DC voltage: 5-24 V DC; 3.3V dc..
since I'll be using 12Vdc motors in my project using an Arduino UNO,, My power supply will be @12 Vdc, which I tested out all good.. including the sensors that triggers and commands/ program works perfectly under 12V DC.
Now, I would like to add an optical sensors which uses IR emt and Recv. they are running at 3.3VDC Max.
i know , I have a dedicated 3.3 VCC on the UNO, but If I use that pin as my source of power, when I assign an Pin for input (the sig from my sensor), would it be taken and detect the HIGH and LOW?
again, I have my 90% of answer, but needed to see if I get confirmation from here...
Thanks a lot for sharing your experience here and taking the time to read my long post!!!
Thanks and have a great Thanksgiving if you are in Canada!!!
Cheers
Bob
3.3V is enough for a reliable high signal (minimum is 2.7V or so - see ATmega328 data sheet for the exact specification).
