Multiples Heat Sensors for Arduino ONU Issue
Hello everyone, my problem is certainly easy to resolve but i am a beginner and i actually don’t know what to do…
I purchased 3x MCP9809 Temp Sensor and i’m trying to read their temperature all together with an Arduino Uno.
Here is my code :
#include <Wire.h>
#include "Adafruit_MCP9808.h"
// Create the MCP9808 temperature sensor object
Adafruit_MCP9808 tempsensor_1 = Adafruit_MCP9808();
Adafruit_MCP9808 tempsensor_2 = Adafruit_MCP9808();
Adafruit_MCP9808 tempsensor_3 = Adafruit_MCP9808();
  Serial.println("MCP9808 demo");
  if (!tempsensor_1.begin(0x18)) {
    Serial.println("Couldn't find MCP9808 #1!");
   while (1);
  if (!tempsensor_2.begin(0x19)) {
   Serial.println("Couldn't find MCP9808 #2!");
   while (1);
  if (!tempsensor_3.begin(0x1A)) {
Serial.println("Couldn't find MCP9808 #3!");
   while (1);
  float c1 = tempsensor_1.readTempC();
  float c2 = tempsensor_2.readTempC();
  float c3 = tempsensor_3.readTempC();
  Serial.print(c1); Serial.print(';'); Serial.print(c2) ; Serial.print(';') ;
 Serial.print(c3) ; Serial.println(';') ;
 delay(3000);
And here is the problem :
The program doesn’t find the sensors related with 0x19 (linked with A0) and 0x1A (linked with A1)…
It always returns “Couldn’t find MCP9808 #2!” (or #3 if i put the line related with the #2 in commentary (//))
The code works with only one sensor ( the one which is not linked with A0,A1 or A2) : (0x18)…
I checked several times my conections and i think they are good, so i guess this is a problem related with the code, but i honestly don’t know what to do as i used the basic example from the MCP9808 website (which works with only one sensor)
I’ll be glad if someone knows how to fix that :wink:
Julo159:
Here is my code :
and here are my code tags [code]  [/code]
The sensor is (assumption) an I2C sensor.
The sensors break outs have 3 pads A0..A2 which must be connected to GND or 5V.
This changes the addres you use.
What you could do is load a I2C scanner and check if it can find 3 sensors with 3 addresses.
download - Arduino Playground - I2cScanner
give it a try.
According to the datasheet you shouldn't leave any of the address pins unconnected. Please provide a wiring diagram of your setup.
Do you use the chip directly or some breakout board? If the later is used, please provide a link to that product.
robtillaart:
give it a try.
Hello, I did it and the program scans only the 0x18 adress, it looks like the A0/A1/A2 doesn't work. Should i buy a new Arduino UNO card ?
Julo159:
If you connect the sensors one at a time, do they all appear as sensor 0x18?
robtillaart:
Yes, if only one is connected (with A0/A1/A2 OR nothing more ( juste vdd/gnd/scl and sda) ) the program only scans the adress 0x18
Now do two tests:
connect 1 sensor to I2C and connect all A0/1/2 to 5V and run the I2C scanner again, what do you see?
connect 1 sensor to I2C and connect all A0/1/2 to GND and run the I2C scanner again, what do you see?
robtillaart:
Now do two tests:
For the first test :
I2C Scanner
Scanning...
I2C device found at address 0x1F !
done
For the second test :
I2C Scanner
Scanning...
I2C device found at address 0x18 !
done
I think i understood the problem, i'll plug the A0...A2 to 5V and it will recognize the sensors #2 and #3 ! doesn't it ? Should i plug also to the A0/A1/A2 from the Arduino uno in addition of 5V or just to 5V?
so the connections look like this map for certain addresses
Address        A0    A1    A2
 18            GND   GND   GND
 19            +5V   GND   GND
 1A            GND   +5V   GND
 1B            +5V   +5V   GND
 1C            GND   GND   +5V
 1D            +5V   GND   +5V
 1E            GND   +5V   +5V
 1F            +5V   +5V   +5V
It's done ! I finally have this :
I2C Scanner
Scanning...
I2C device found at address 0x19 !
I2C device found at address 0x1C !
done
So my 3 sensors work and i can go further in my project ! Thank you Rob Tillaart :smiley:
Julo159:
I2C Scanner
Scanning...
done
Actually I put the first code i gave you in this topic and now i have the error message : Couldn't find MCP9808 #1
However your program finds the adress 0x18.... What's the problem here?
Julo159:
try to add a Wire.begin(); statement in setup()
robtillaart:
I think i found the problem, one of my sensor is broken because of my bad solder....
I have this :
20.37;0.00;20.19;
20.31;0.00;20.19;
20.31;0.00;20.12;
20.31;0.00;20.12;
20.31;0.00;20.06;
20.25;0.00;20.06;
20.25;0.00;20.06;
20.19;0.00;20.06;
20.19;0.00;20.00;
20.12;0.00;20.00;
The adress is OK but i have a temperature of 0° which is obviously not the case.
As the code is the same for the 3 sensors it must be a problem related with the #2... It must be unfunctional !
Actually i really need just 2 sensors so it's ok ^^
Thank's again
