Hello, for the last few days I've been struggling to set up a working serial communication between two Arduino UNO's. Right now the communication problem itself has been solved, but it brought another with it: It interrupts a different proces, the multiplexing of two 7 segment displays.
To give a sketch of the whole situation: We are making a robot that is supposed to follow a line and has to load or unload at designated points. While it is driving it shows if its loaded or not and how many pieces of cargo it has had. This has to be done with multiplexing.
The multiplexing should be a proces that should always be on while the on switch has been pressed, but in the moment that the Arduino's communicate with eachother the multiplexing stops.
Video: https://puu.sh/D4ADD/e150972ec7.mp4
Is there a way to make it communicate and multiplex at the same time?
Parts in use with testing this code:
- 2x arduino UNO
- 2x L298P Shield (v1.2 and v1.3)
- 1x LEGO motor
- 2x 7 Segment display (SC52-115RWA)
- 1x standard(?) switch
I translated the code for (maybe) easier reading, but I might have missed some things.
There are also pieces of code for the motors, you can ignore those.
Code Arduino 1:
#define M1 4 //Motor left direction
#define E1 5 //Motor left speed
#define E2 6 //Motor right speed
#define M2 7 //Motor right direction
#define LS1 A0 //Sensor far left
#define LS3 A1 //Sensor left
#define LS2 A2 //Sensor right
#define LS4 A3 //Sensor far right
pinMode(E1, OUTPUT);
pinMode(M1, OUTPUT);
pinMode(E2, OUTPUT);
pinMode(M2, OUTPUT);
pinMode(LS1, INPUT);
pinMode(LS2, INPUT);
pinMode(LS3, INPUT);
pinMode(LS4, INPUT);
int val1;
int val2;
int val3;
int val4;
int turn = 4000; //Test: time needed to turn 90 degrees.
const int black = 500;
bool loaded = false;
bool sent = false;
bool on = false;
if (on) {
//Infinite loop to test communication
if (!sent) {
if (loaded) {
serialOutput("unload");
serialOutput("load");
//Make proper reset
stopMotors();
sent = false;
while (Serial.available() > 0) {
serialInput();
delay(10);
//------------- Motor controls -------------
void motor1(int PWM, boolean forward) {
analogWrite(E1, PWM);
if (forward) {
digitalWrite(M1, HIGH);
digitalWrite(M1, LOW);
void motor2(int PWM, boolean forward) {
analogWrite(E2, PWM);
if (forward) {
digitalWrite(M2, LOW);
digitalWrite(M2, HIGH);
void forward() {
motor1(255, true);
motor2(255, true);
void backwards() {
motor1(255, false);
motor2(255, false);
void left() {
motor1(255, false);
motor2(255, true);
void right() {
motor1(255, true);
motor2(255, false);
void adjustLeft() {
motor1(180, true);
motor2(240, true);
void adjustRight() {
motor1(240, true);
motor2(180, true);
void turnAround() {
motor1(255, false);
motor2(255, true);
void stopMotors() {
motor1(0, false);
motor2(0, false);
//------------- Serial communication -------------
void serialInput() {
String input = Serial.readString();
if (input.substring(0, 9) == "on_device") {
on = true;
if (input.substring(0, 9) == "of_device") {
on = false;
if (on) {
if (input.substring(0, 6) == "loaded") {
loaded = true;
sent = false;
if (input.substring(0, 8) == "unloaded") {
loaded = false;
sent = false;
void serialOutput(String output) {
Serial.println(output);
sent = true;
Code Arduino 2:
#define M3 4
#define E3 5
#define LDRpin A0
#define KNOP 2 //ON/OFF
int LDRvalue = 0;
int cargo = 0; //Number of the cargo being moved
bool on = false;
bool on_display = false;
bool pressed = false;
pinMode(LDRpin, INPUT);
pinMode(KNOP, INPUT_PULLUP);
pinMode(3, OUTPUT);
pinMode(6, OUTPUT);
pinMode(M3, OUTPUT);
pinMode(E3, OUTPUT);
pinMode(7, OUTPUT);
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);
pinMode(10, OUTPUT);
pinMode(11, OUTPUT);
pinMode(12, OUTPUT);
pinMode(13, OUTPUT);
if (!pressed) {
if (digitalRead(KNOP) == LOW) {
if (on) {
//Make proper reset
on = false;
cargo = 0;
loaded = false;
Serial.println("of_device");
on = true;
Serial.println("on_device");
pressed = true;
if (digitalRead(KNOP) == HIGH) {
pressed = false;
if (on) {
on_display = true;
on_display = false;
multiplex(1);
serialInput();
void motor(int PWM, boolean up) {
analogWrite(E3, PWM);
if (up) {
digitalWrite(M3, HIGH);
digitalWrite(M3, LOW);
void load() {
motor(255, true);
multiplex(1000);
motor(0, false);
cargo++;
loaded = true;
Serial.println("loaded");
void unload() {
motor(255, false);
multiplex(850);
motor(0, true);
loaded = false;
Serial.println("unloaded");
//------------- 7 segment display 1 -------------
void e() {
digitalWrite(3, LOW);
digitalWrite(6, HIGH);
digitalWrite(7, HIGH);
digitalWrite(8, HIGH);
digitalWrite(9, HIGH);
digitalWrite(10, HIGH);
digitalWrite(11, LOW);
digitalWrite(12, HIGH);
digitalWrite(13, LOW);
void l() {
digitalWrite(6, LOW);
digitalWrite(8, LOW);
void counter(int tel) {
if (tel == 0) {
zero();
} else if (tel == 1) {
one();
} else if (tel == 2) {
two();
zero();
//------------- 7 segment display 2 -------------
void zero() {
digitalWrite(3, HIGH);
digitalWrite(11, HIGH);
digitalWrite(12, LOW);
digitalWrite(13, HIGH);
void one() {
digitalWrite(7, LOW);
digitalWrite(9, LOW);
digitalWrite(10, LOW);
void two() {
void ledOff() {
//------------- 7 segment displays combined -------------
void multiplex(int steps) {
if (on_display) {
for (int i = 0; i < steps; i++) {
if (loaded) {
l();
delay(2);
counter(cargo);
delay(2);
e();
delay(2);
counter(cargo);
delay(2);
ledOff();
if (on) {
if (input.substring(0, 4) == "load") {
if (!loaded) {
load();
if (input.substring(0, 6) == "unload") {
if (loaded) {
unload();
