Multiplexer 4067
hi, all, my question is that, can i connect a multiplexer on digital pin in Arduino Uno?
if i connect to hc4067 to pin A2 is working fine, but if i connect it at PIN10 is not working.
THE FIRST CODE IS WORKING, if now i change pin A2 TO PIN 10 is not working.
from what i know all pin in arduino are digital inputs. now seams i missing something.
Multiplexer4067 mplexButtons1 = Multiplexer4067(4, 5, 6, 7, 10);
pinMode(10, INPUT_PULLUP); // Buttons need input pull up
// Multiplexer
Multiplexer4067 mplexPots = Multiplexer4067(4, 5, 6, 7, A0);
Multiplexer4067 mplexButtons = Multiplexer4067(4, 5, 6, 7, A1);
Multiplexer4067 mplexButtons1 = Multiplexer4067(4, 5, 6, 7, A2);
// threads - programa cada atividade do Arduino para acontecer em um determinado tempo
ThreadController cpu; //thread master, onde as outras vao ser adicionadas
Thread threadReadPots; // thread para controlar os pots
Thread threadReadButtons; // thread para controlar os botoes
Thread threadReadButtons1;
  Serial.begin(115200); // 115200 for hairless - 31250 for MOCO lufa
  MIDI.turnThruOff();
  // Midi in
  MIDI.setHandleControlChange(handleControlChange);
  MIDI.setHandleNoteOn(handleNoteOn);
  MIDI.setHandleNoteOff(handleNoteOff);
  // Multiplexers
  mplexPots.begin(); // inicializa o multiplexer
  mplexButtons.begin(); // inicializa o multiplexer
  mplexButtons1.begin(); // inicializa o multiplexer
  pinMode(A1, INPUT_PULLUP); // Buttons need input pull up
  pinMode(A2, INPUT_PULLUP); // Buttons need input pull up
// Multiplexer
  MIDI.turnThruOff();
  // Midi in
  // Multiplexers
Please, post a wiring diagram. Word sallad can never do the job.
Post the entire code, autoformatted in the IDE, using code tags, </>, here.
You didn't post the complete code, and you didn't mention which libraries you're using, so it's impossible to tell whether it can be done using these libraries.
However, it should be possible using a library that reads the input pins correctly using digitalRead.
For example, the Control Surface library I maintain supports this out of the box:
this is the code, i have modify few thinks, because need to use 3 hc4067. like i said if i conect the thirt hc4067 to pin A2 and change the parameters is working, if i conect it to pin no10 and change A2 TO pin10 is not. the library is <Multiplexer4067.h> thank u for any help.
https://github.com/sumotoy/Multiplexer4067
// PWM bit shifter
// You can choose the latch pin yourself.
const int ShiftPWM_latchPin = 8;
// ** uncomment this part to NOT use the SPI port and change the pin numbers. This is 2.5x slower **
#define SHIFTPWM_NOSPI
const int ShiftPWM_dataPin = 11;
const int ShiftPWM_clockPin = 12;
// If your LED's turn on if the pin is low, set this to true, otherwise set it to false.
const bool ShiftPWM_invertOutputs = false;
// You can enable the option below to shift the PWM phase of each shift register by 8 compared to the previous.
// This will slightly increase the interrupt load, but will prevent all PWM signals from becoming high at the same time.
// This will be a bit easier on your power supply, because the current peaks are distributed.
const bool ShiftPWM_balanceLoad = false;
// LIBRARIES
#include <ShiftPWM.h>  // Bit shifter library >> https://github.com/elcojacobs/ShiftPWM - include ShiftPWM.h after setting the pins!
// If using with ATmega328 - Uno, Mega, Nano...
#include <MIDI.h> // MIDI library (by Forty Seven Effects) >> https://github.com/FortySevenEffects/arduino_midi_library/releases/tag/4.3.1
MIDI_CREATE_DEFAULT_INSTANCE();
#include <Multiplexer4067.h> // Multiplexer CD4067 library >> https://github.com/sumotoy/Multiplexer4067
#include <Thread.h> // Threads library (by Ivan seidel) >> https://github.com/ivanseidel/ArduinoThread
#include <ThreadController.h>
#include <Encoder.h> // Encoder library >> https://github.com/PaulStoffregen/Encoder
// buttons
const byte muxNButtons = 16; // *coloque aqui o numero de entradas digitais utilizadas no multiplexer
const byte NButtons = 1; // *coloque aqui o numero de entradas digitais utilizadas
const byte totalButtons = muxNButtons + NButtons;
const byte muxButtonPin[muxNButtons] = {0, 1, 2, 3, 4, 5, 9, 10, 11, 12, 13, 14, 15 , 6, 7, 8,}; // *neste array coloque na ordem desejada os pinos das portas digitais utilizadas
const byte buttonPin[NButtons] = {9}; // *neste array coloque na ordem desejada os pinos das portas digitais utilizadas
int buttonCState[totalButtons] = {0}; // estado atual da porta digital
int buttonPState[totalButtons] = {0}; // estado previo da porta digital
// buttons
const byte muxNButtons1 = 16; // *coloque aqui o numero de entradas digitais utilizadas no multiplexer
const byte NButtons1 = 1; // *coloque aqui o numero de entradas digitais utilizadas
const byte totalButtons1 = muxNButtons1 + NButtons1;
const byte muxButtonPin1[muxNButtons1] = {0, 1, 2, 3, 4, 5, 9, 10, 11, 12, 13, 14, 15 , 6, 7, 8,}; // *neste array coloque na ordem desejada os pinos das portas digitais utilizadas
const byte buttonPin1[NButtons1] = {9}; // *neste array coloque na ordem desejada os pinos das portas digitais utilizadas
int buttonCState1[totalButtons1] = {0}; // estado atual da porta digital
int buttonPState1[totalButtons1] = {0}; // estado previo da porta digital
// debounce
unsigned long lastDebounceTime = 0;  // the last time the output pin was toggled
unsigned long debounceDelay = 5;    // the debounce time; increase if the output flickers
// potentiometers
const byte NPots = 16; // *coloque aqui o numero de entradas analogicas utilizadas
const byte muxPotPin[NPots] = {0, 1, 2, 3, 4, 5, 6, 15, 14, 13, 12, 11, 10, 9, 8, 7}; // *neste array coloque na ordem desejada os pinos das portas analogicas, ou mux channel, utilizadas
int potCState[NPots] = {0}; // estado atual da porta analogica
int potPState[NPots] = {0}; // estado previo da porta analogica
int potVar = 0; // variacao entre o valor do estado previo e o atual da porta analogica
int lastCcValue[NPots] = {0};
// pot reading
int TIMEOUT = 50; //quantidade de tempo em que o potenciometro sera lido apos ultrapassar o varThreshold
byte varThreshold = 8; //threshold para a variacao no sinal do potenciometro
boolean potMoving = true; // se o potenciometro esta se movendo
unsigned long pTime[NPots] = {0}; // tempo armazenado anteriormente
unsigned long timer[NPots] = {0}; // armazena o tempo que passou desde que o timer foi zerado
// encoder
Encoder myEnc(3, 2);
long oldPosition  = -10;
// midi
byte midiCh = 1; // is changing the channel
byte note = 36; // *Nota mais grave que sera utilizada
byte cc = 1; // *CC mais baixo que sera utilizado
int ccLastValue = 0;
// Leds
const byte ledNum = 24; // total number of leds used
unsigned char maxBrightness = 255;
unsigned char pwmFrequency = 75;
unsigned int numRegisters = 3;
unsigned int numOutputs = numRegisters * 8;
unsigned int numRGBLeds = numRegisters * 8 / 3;
unsigned int fadingMode = 0; //start with all LED's off.
unsigned int VuL[7] = {1, 2, 3, 4, 5, 6, 7}; // VU left pins
unsigned int VuR[7] = {15, 14, 13, 12, 11, 10, 9}; // VU righ pins
unsigned int buttonsLedL[5] = {20, 19, 18, 17, 16};
unsigned int buttonsLedR[5] = {8, 0, 23, 22, 21};
unsigned int red = 180;
unsigned int green = 255;
unsigned int blue = 10;
unsigned int yellow = 100;
//byte ledOnOffPin = 10; //On Off pin
// Multiplexer
  MIDI.turnThruOff();
  // Midi in
  // Multiplexers
  // buttons on Arduino Digital pins
  for (int i = 0; i < NButtons; i++) { // buttons on Digital pin
    pinMode(buttonPin[i], INPUT_PULLUP);
  // Leds
  //  leds.setBitCount(ledNum); // Mux Leds
  //  leds.setPins(clockPin, dataPin, latchPin);
//  pinMode(ledOnOffPin, OUTPUT);
  // Sets the number of 8-bit registers that are used.
  ShiftPWM.SetAmountOfRegisters(numRegisters);
  ShiftPWM.SetAll(0);
  // SetPinGrouping allows flexibility in LED setup.
  // If your LED's are connected like this: RRRRGGGGBBBBRRRRGGGGBBBB, use SetPinGrouping(4).
  ShiftPWM.SetPinGrouping(1); //This is the default, but I added here to demonstrate how to use the funtion
  ShiftPWM.Start(pwmFrequency, maxBrightness);
  // threads
  // pots
  threadReadPots.setInterval(10);
  threadReadPots.onRun(readPots);
  cpu.add(&threadReadPots);
  // buttons
  threadReadButtons.setInterval(20);
  threadReadButtons.onRun(readButtons);
  cpu.add(&threadReadButtons);
  // buttons
  threadReadButtons1.setInterval(20);
  threadReadButtons1.onRun(readButtons1);
  cpu.add(&threadReadButtons1);
  //leds
  //analogWrite(ledOnOffPin, 255); // on/off led
//  for (int i = 0; i < ledNum; i++) { // writeBit works just like digitalWrite
//    ShiftPWM.SetOne(i, LOW);
  cpu.run();
  MIDI.read();
  readEncoder();
// read buttons
void readButtons() {
  for (int i = 0; i < muxNButtons; i++) { //reads buttons on mux
    int buttonReading = mplexButtons.readChannel(muxButtonPin[i]);
    //buttonCState[i] = map(mplex.readChannel(muxButtonPin[i]), 22, 1023, 0, 2); // stores on buttonCState
    if (buttonReading > 100) {
      buttonCState[i] = HIGH;
    else {
      buttonCState[i] = LOW;
    //Serial.print(buttonCState[i]); Serial.print("   ");
  //Serial.println();
  for (int i = 0; i < NButtons; i++) { //read buttons on Arduino
    buttonCState[i + muxNButtons] = digitalRead(buttonPin[i]); // stores in the rest of buttonCState
  for (int i = 0; i < totalButtons; i++) {
    if ((millis() - lastDebounceTime) > debounceDelay) {
      if (buttonCState[i] != buttonPState[i]) {
        lastDebounceTime = millis();
        if (buttonCState[i] == LOW) {
          //          noteOn(potMidiCh(), note + i, 127);  // Channel 0, middle C, normal velocity
          //          MidiUSB.flush();
          MIDI.sendNoteOn(note + i, 127, midiCh); // envia NoteOn(nota, velocity, canal midi)
          //Serial.print("Note: "); Serial.print(note + i); Serial.println(" On");
          buttonPState[i] = buttonCState[i];
        else {
          //          noteOn(potMidiCh(), note + i, 0);  // Channel 0, middle C, normal velocity
          //          MidiUSB.flush();
          MIDI.sendNoteOn(note + i, 0, midiCh);
          //Serial.print("Note: "); Serial.print(note + i); Serial.println(" Off");
// read buttons1
void readButtons1() {
  for (int i = 0; i < muxNButtons1; i++) { //reads buttons on mux
    int buttonReading1 = mplexButtons1.readChannel(muxButtonPin1[i]);
    if (buttonReading1 > 100) {
      buttonCState1[i] = HIGH;
    else {
      buttonCState1[i] = LOW;
  //Serial.println();
  for (int i = 0; i < NButtons1; i++) { //read buttons on Arduino
    buttonCState1[i + muxNButtons1] = digitalRead(buttonPin1[i]); // stores in the rest of buttonCState
  for (int i = 0; i < totalButtons1; i++) {
      if (buttonCState1[i] != buttonPState1[i]) {
        if (buttonCState1[i] == LOW) {
          //          MidiUSB.flush();
          MIDI.sendNoteOn(note + i, 127, 2); // envia NoteOn(nota, velocity, canal midi)
          buttonPState1[i] = buttonCState1[i];
        else {
          //          MidiUSB.flush();
          MIDI.sendNoteOn(note + i, 0, 2);
//read potentiometers
void readPots() {
  for (int i = 0; i < NPots; i++) { // le todas entradas analogicas utilizadas, menos a dedicada a troca do canal midi
    potCState[i] = mplexPots.readChannel(muxPotPin[i]);
    potVar = abs(potCState[i] - potPState[i]); // calcula a variacao da porta analogica
    if (potVar >= varThreshold) {  //sets a threshold for the variance in the pot state, if it varies more than x it sends the cc message
      pTime[i] = millis(); // armazena o tempo previo
    timer[i] = millis() - pTime[i]; // reseta o timer
    if (timer[i] < TIMEOUT) { // se o timer for menor que o tempo maximo permitido significa que o potenciometro ainda esta se movendo
      potMoving = true;
    else {
      potMoving = false;
    if (potMoving == true) { // se o potenciometro ainda esta se movendo, mande o control change
      int ccValue = map(potCState[i], 0, 1023, 0, 127);
      if (lastCcValue[i] != ccValue) {
        //        controlChange(11, cc + i, ccValue); // manda control change (channel, CC, value)
        //        MidiUSB.flush();
        MIDI.sendControlChange(cc + i, map(potCState[i], 0, 1023, 0, 127), 11); // envia Control Change (numero do CC, valor do CC, canal midi)
        //Serial.print("CC: "); Serial.print(cc + i); Serial.print(" value:"); Serial.println(map(potCState[i], 0, 1023, 0, 127));
        potPState[i] = potCState[i]; // armazena a leitura atual do potenciometro para comparar com a proxima
        lastCcValue[i] = ccValue;
//// read encoder
void readEncoder () {
  int newPosition = myEnc.read();
  int encoderVal = map(newPosition, -1024, 1024, -256, 256);
  int encoderValue;
  if (encoderVal != oldPosition) {
    if ((encoderVal - oldPosition) > 0) {
      encoderValue = 127;
    else {
      encoderValue = 1;
    MIDI.sendControlChange(14, encoderValue, 1);
    oldPosition = encoderVal;
// led feedback
void handleControlChange(byte channel, byte number, byte value) {
  //handleControlChange
  //int value_ = round(map(value, 0, 127, 0, 7));
  int value_ = value;
  if (value_ != ccLastValue) {
    // Left VU
    if (number == 12) {
      switch (value_) {
        case 0:
          for (int i = 0; i < 7; i++) {
            ShiftPWM.SetOne(VuL[i], LOW);
        case 1:
          for (int i = 1; i < 7; i++) {
          ShiftPWM.SetOne(VuL[0], green);
        case 2:
          for (int i = 2; i < 7; i++) {
          for (int i = 0; i < 2; i++) {
            ShiftPWM.SetOne(VuL[i], green);
        case 3:
          for (int i = 3; i < 7; i++) {
          for (int i = 0; i < 3; i++) {
        case 4:
          for (int i = 4; i < 7; i++) {
          for (int i = 0; i < 4; i++) {
        case 5:
          for (int i = 5; i < 7; i++) {
          for (int i = 0; i < 5; i++) {
        case 6:
          for (int i = 6; i < 7; i++) {
          ShiftPWM.SetOne(VuL[5], yellow);
        case 7:
          ShiftPWM.SetOne(VuL[6], red);
    // Right VU
    if (number == 13) {
      switch (value_) {
        case 0:
            ShiftPWM.SetOne(VuR[i], LOW);
        case 1:
          ShiftPWM.SetOne(VuR[0], green);
        case 2:
            ShiftPWM.SetOne(VuR[i], green);
        case 3:
        case 4:
        case 5:
        case 6:
          ShiftPWM.SetOne(VuR[5], yellow);
        case 7:
          ShiftPWM.SetOne(VuR[6], red);
    ccLastValue = value;
void handleNoteOn(byte channel, byte number, byte value)
  switch (number) {
    // Left buttons
    case 40: //sync
      ShiftPWM.SetOne(buttonsLedL[0], blue);
    case 39: //cue
      ShiftPWM.SetOne(buttonsLedL[1], blue);
    case 38: //play
      ShiftPWM.SetOne(buttonsLedL[2], blue);
    case 37: //phones
      ShiftPWM.SetOne(buttonsLedL[3], blue);
    case 36: //filter on
      ShiftPWM.SetOne(buttonsLedL[4], blue);
    // Righ buttons
    case 44: //sync
      ShiftPWM.SetOne(buttonsLedR[0], blue);
    case 45: //cue
      ShiftPWM.SetOne(buttonsLedR[1], blue);
    case 46: //play
      ShiftPWM.SetOne(buttonsLedR[2], blue);
    case 47: //phones
      ShiftPWM.SetOne(buttonsLedR[3], blue);
    case 48: //filter on
      ShiftPWM.SetOne(buttonsLedR[4], blue);
void handleNoteOff(byte channel, byte number, byte value) {
  switch (number) {
    // Left buttons
    case 40: //sync
      ShiftPWM.SetOne(buttonsLedL[0], LOW);
    case 39: //cue
      ShiftPWM.SetOne(buttonsLedL[1], LOW);
    case 38: //play
      ShiftPWM.SetOne(buttonsLedL[2], LOW);
    case 37: //phones
      ShiftPWM.SetOne(buttonsLedL[3], LOW);
      ShiftPWM.SetOne(buttonsLedL[4], LOW);
    // Righ buttons
    case 44: //sync
      ShiftPWM.SetOne(buttonsLedR[0], LOW);
    case 45: //cue
      ShiftPWM.SetOne(buttonsLedR[1], LOW);
    case 46: //play
      ShiftPWM.SetOne(buttonsLedR[2], LOW);
    case 47: //phones
      ShiftPWM.SetOne(buttonsLedR[3], LOW);
      ShiftPWM.SetOne(buttonsLedR[4], LOW);
  buttons midi order
  40 44 - sync
  39 45 - cue
  38 46 - play
  37 47 - phones
  36 48 - filter
     VU order
  7 9
  6 10
  5 11
  4 12
  3 13
  2 14
  1 15
*/`Preformatted text`
This library does not support digital inputs:
@tasoscy where is the exact library you are using (successfully) so far?
What about if you try another pin, not 10? Without being on hands and knees, I am suspicious that pin 10 is used w/o your exact awareness, in some other way.
a7
He posted the name and a link to it.
As pointed out in my previous post, the problem is the library using analogRead() to read the state of the pin, which won't work for a digital pin like pin 10.
OP doesn't seem to be using SPI, and at first glance I don't see anything else in his code that could be using pin 10.
Yes, yes he did missed it entirely, THX.
And it is now time for coffee. :expressionless:
a7
in the schematic pin10 is connect to a led, but if you see in the code, i disable the commands that are making pin10 to use for led.
can u tell me a library that it can do that please, but not need to change to much in the code.
am newbie in this. :slight_smile:
Please see the links in my first post. You can just use the CD74HC4051 class without changing anything else if you don't want to.
you mean i need to at this in the code, or to add this in the library :slight_smile: sorry if it sound stupid, but am very very new to this.
no my friend i cant do that, hardware part is been done with many hours of work.
I'm not sure what you mean, I'm referring to this code: Control Surface: 2.DigitalReadSerial.ino
You can download the library here: GitHub - tttapa/Control-Surface: Arduino library for creating MIDI controllers and other MIDI devices.
The installation instructions are here: Control Surface: Installation
That was a typo, I meant the CD74HC4067 class, again, please refer to the example I posted earlier.
