Multiplexer & 7 segment LED display advice!
:)Hello to all! I'm slightly perplexed at which multiplexer or device to use with just one 7 segment LED display! I want some advice on the simplest and or cheapest to use. There is the possibility then that I may use two 7 segment displays together for double digits! Any advice appreciated thanks, Goatboy :)
2 7 segment led displays = 14 individual led's this could be run from Arduino without multiplexing or anything but a current limiting resistor for each LED segment.
You can also get IC's that are dedicated to drive 7 segment LED's.
Check this:
http://www.play-hookey.com/digital/experiments/seven_seg_driver.html
Thanks MikMo! Is the 4511 basically the same for all the different company's that seem to make it? Goatboy :)
Yes they probably are, but it is always a good idea to check the individual one you look at at www.alldatasheet.com. They often have extra letters at the end like CD4511XXX. These letters has a meaning.
Sometimes they indicate a through hole package (DIL) or surface mount package (SMD) sometimes they indicate that the IC has built in buffer or not.
Excellent! Thanks :)
