Multiplexer has 3 voltage supply input pins
I'm using the 4051 multiplexer. (HCF4051B: http://www.st.com/stonline/books/pdf/docs/2053.pdfE). I'm confused as to why it has 3 supply voltage pins:
(cut and pasted from pages 1 and 2 of official documentation that I linked to above):
I found this picture online from someone who seems to have connected common ground to both VEE and VSS:
Post: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1238811578
Link to pic: http://xelentdesign.com/arduino4051wiring.jpg
Reproduced here:
This implies that VEE and VSS can be connected to common ground, but I'm wondering why is the chip constructed with these two pins separate t begin with? In what situations would the pins be used separately?
it can pass analog signals which are often AC having a + voltage and a - voltage in reference to ground (which is usually half way tween the 2)
Why? Probably something to with handling some type of negative signal level comming into the chip. I connect the Vss and Vee together as I think on a data sheet example they are shown connected.
