Hi, i have two seeed studio oled displays connected to a TCA9548A to an arduino nano esp32. the problem is that all of my display is going to the screen in the port 1, even though I select port 0. I have no idea what's causing this or how to fix it.
* List item
#include <Wire.h>
#include <Arduino.h>
#include <U8g2lib.h>
U8G2_SSD1306_128X64_NONAME_F_SW_I2C u8g2a(U8G2_R0, /* clock=*/ SCL, /* data=*/ SDA, /* reset=*/ U8X8_PIN_NONE); // All Boards without Reset of the Display
U8G2_SSD1306_128X64_NONAME_F_SW_I2C u8g2b(U8G2_R0, /* clock=*/ SCL, /* data=*/ SDA, /* reset=*/ U8X8_PIN_NONE);
// Select I2C BUS
void TCA9548A(uint8_t bus){
Wire.beginTransmission(0x70); // TCA9548A address
Wire.write(1 << bus); // send byte to select bus
Wire.endTransmission();
Serial.println(bus);
void NOTCA9548A(){
Wire.write(0); // no channel selected
Serial.println("starting");
// Start I2C communication with the Multiplexer
Wire.begin();
TCA9548A(1);
u8g2a.begin();
NOTCA9548A();
TCA9548A(0);
u8g2b.begin();
NOTCA9548A();
// Write to OLED on bus number 0
TCA9548A(1);
delay(100);
u8g2a.clearBuffer();
u8g2a.setFont(u8g2_font_ncenB08_tr);
u8g2a.drawStr(32,30,"I am \n");
u8g2a.drawStr(32,45,"Screen 1 \n");
u8g2a.sendBuffer();
NOTCA9548A();
TCA9548A(0);
delay(100);
u8g2b.clearBuffer();
u8g2b.setFont(u8g2_font_ncenB08_tr);
u8g2b.drawStr(32,30,"I am \n");
u8g2b.drawStr(32,45,"Screen 2 \n");
u8g2b.sendBuffer();
NOTCA9548A();
so the problem is that the oled connected to the port 1 switches between saying screen 1 and screen 2 and the oled connected to port 0 stays blank
Your circuit is a mess. That's why it doesn't work.
You should plug the multiplexer and the OLEDs into the breadboard. That's what breadboards are for. If the breadboard isn't big enough, get a bigger one, or get several the same and clip them together to make one that is big enough.
This looks to me like the PCB headers have been pushed into the module (probably because there wasn't enough space on the breadboard). Are these headers soldered to the module? I guess not. This will not work. PCB headers must be soldered to the module. Pushing them into the bare holes will never make a reliable connection on all the pins at the same time.
Are the PCB pins soldered to the ESP32, or are they also pushed into the bare holes?
In summary:
Get a breadboard big enough for all your components. Clip multiple breadboards together if necessary.
Solder PCB headers to all modules as needed.
Check all Dupont cables with a multimeter before using them. They are notoriously unreliable.
Use solid-core hookup wire, cut to length and laid flat on the breadboard, in preference to Dupont wires. This type of wire can also unreliable, but you can easily tell when it is broken because it is suddenly no longer rigid.
