Hi all.
Im trying to make a small form factor energy monitor so im using a nodemcu and multiplexing the 1 analogue input.
the goal is to send it to a dashboard and be able to get reports on daily usage and alarms etc.
Im currently trialling adafruit.io as it the highest data rate/per min I can find for free. Im updating the feeds every 2 seconds .
As its still under construction I’m simulating the analogue inputs with pots. For the prototype im using ACS712 30A current sensors, eventually ill move to current transformers. The next step is to integrate the power measurement.
here is what I currently have working:
#define IO_USERNAME "xxxxxx"
#define IO_KEY "xxxxxxxxxxxxxxxxxxxxxxxxx"
#define WIFI_SSID "xxxxxxxxxxxxxxxxxxx"
#define WIFI_PASS "xxxxxxxxxxxxxxxxxxxxxx"
#include "AdafruitIO_WiFi.h"
AdafruitIO_WiFi io(IO_USERNAME, IO_KEY, WIFI_SSID, WIFI_PASS);
#define MUX_A D4
#define MUX_B D3
#define MUX_C D2
#define ANALOG_INPUT A0
#include "config.h"
#define INTERVAL_MESSAGE1 2000 //is this right for a 2s delay?
#define INTERVAL_MESSAGE2 2000
int LED1 = D0;
int LED2 = D1;
int LED3 = D5;
int LED4 = D6;
int LED5 = D7;
int LED6 = D8;
unsigned long time_1 = 0;
unsigned long time_2 = 0;
AdafruitIO_Feed *grid = io.feed("grid");
AdafruitIO_Feed *solar1 = io.feed("solar1");
void print_time(unsigned long time_millis);
void changeMux(int c, int b, int a)
digitalWrite(MUX_A, a);
digitalWrite(MUX_B, b);
digitalWrite(MUX_C, c);
// start the serial connection
// wait for serial monitor to open
while(! Serial);
Serial.print("Connecting to Adafruit IO");
// connect to io.adafruit.com
io.connect();
// wait for a connection
while(io.status() < AIO_CONNECTED) {
Serial.print(".");
// we are connected
Serial.println(io.statusText());
//Deifne output pins for Mux
pinMode(MUX_A, OUTPUT);
pinMode(MUX_B, OUTPUT);
pinMode(MUX_C, OUTPUT);
io.run();
float value;
changeMux(LOW, LOW, LOW);
changeMux(LOW, LOW, HIGH);
if(millis() > time_1 + INTERVAL_MESSAGE1){
time_1 = millis();
print_time(time_1);
value = analogRead(ANALOG_INPUT); //Value of the sensor connected Option 1 pin of Mux
Serial.print("sending -> ");
Serial.println(value);
solar1->save(value);
changeMux(LOW, HIGH, LOW);
if(millis() > time_2 + INTERVAL_MESSAGE2){
time_2 = millis();
print_time(time_2);
value = analogRead(ANALOG_INPUT); //Value of the sensor connected Option 2 pin of Mux
grid->save(value);
void print_time(unsigned long time_millis){
Serial.print("Time: ");
Serial.print(time_millis/1000);
Serial.print("s - ");
I need to integrate some code a little like this to take power measurements :
#define CURRENT_SENSOR A0 // Define Analog input pin that sensor is attached
float amplitude_current; // Float amplitude current
float effective_value; // Float effective current
pins_init();
int sensor_max;
sensor_max = getMaxValue();
Serial.print("sensor_max = ");
Serial.println(sensor_max);
//the VCC on the Arduino interface of the sensor is 5v
amplitude_current=(float)(sensor_max-512)/1024*5/185*1000000; // for 5A mode,you need to modify this with 20 A and 30A mode;
effective_value=amplitude_current/1.414;
//for minimum current=1/1024*5/185*1000000/1.414=18.7(mA)
//Only sinusoidal alternating current
Serial.println("The amplitude of the current is(in mA)");
Serial.println(amplitude_current,1);
//Only one number after the decimal point
Serial.println("The effective value of the current is(in mA)");
Serial.println(effective_value,1);
void pins_init()
pinMode(CURRENT_SENSOR, INPUT);
/*Function: Sample for 1000ms and get the maximum value from the S pin*/
int getMaxValue()
int sensorValue; //value read from the sensor
int sensorMax = 0;
uint32_t start_time = millis();
while((millis()-start_time) < 1000) //sample for 1000ms
sensorValue = analogRead(CURRENT_SENSOR);
if (sensorValue > sensorMax)
/*record the maximum sensor value*/
sensorMax = sensorValue;
return sensorMax;
I cant get my head around the mux timing(and others) I have the mux sampling the A0 at one rate, pushing data to the dashboard feed at another and the power measurement requires sampling of 1 second to work.
Can anyone point me in the right direction for setting this up, up till now my cut n paste and my limited understanding has got me by.
I’m keen to learn so I’m not asking anyone to write the code for me but any suggestions would be really helpful.
Thanks
