I am new to Arduino, so I have some simple questions about using an Arduino Mega 2560 to communicate to some multiplexers (MUX36S16). My goal is to use 4 of the digital I/O pins to send signals to each multiplexer to select an input on the multiplexer. I am looking for some help on setting pins HIGH and LOW and to configure the I/O pins to be set as outputs. If anyone could direct me to someone else's post or some sample code, that would be amazing. Thank you in advance for your help.
Looks to me you don't even started yet... Did you even open standard examples like the most basic one like Blink? What questions can you possible have about "setting pins HIGH and LOW and to configure the I/O pins to be set as outputs" after looking at that... :
digitalWrite(PIN10 , HIGH); // turn PIN 10 on
delay(1000); // wait for a second
digitalWrite(PIN10 , LOW); // turnPIN 10 off
septillion:
So you copied your version of Blink... But what about it?
PS
#define PIN10 10
Most terrible name of today defined in the most terrible way...
I hope this version is better for you, but certainly worse for wsbz001.
pinMode(SS, OUTPUT); // set Pin 10 as output
digitalWrite(SS, HIGH); // turn Pin 10 on
digitalWrite(SS, LOW); // turn Pin 10 off
Look at the following diagram and then use pinMode() function to set the directions of the digital IO lines as indicated. There is no need to initialize the direction of analog line A0; it will be automatically working as input when this instruction is executed: analogRead(A0);.
