Multiplexing I2C
Lets assume I want to speak with 16 I2C devices simultaniously. The catch: They all have the same address and I cannot change it.
Could I multiplex the signal? How would I go about it?
My initial approach was to connect all SCL lines together. The SDA line goes through the multiplexer and addresses one at a time. I tried this but it didn't work as expected.
Is what I am trying to do possible in theory? or would the multiplexer mess up the timing? could I somehow introduce a delay on SCL to make them sync again?
I'll try to isolate exactly where the problem is tomorrow. I'll also post my code then. (Its 2:30 in the morning here, and I feel like I should give it another look tomorrow morning before I post it.)
Anyway, if somebody knows whether this is even possible, or has any general comments until then, I would appreciate that.
Regards
p.
It's possible; I've done multiplexing between 2 I2C devices with the same address (nintendo nunchucks). I did it the same way you mention; hardwire all SCL lines but multiplex the SDA lines. I used npn transistors, but here is the right approach to a trouble-free setup:
16 channel multiplexer, controlled by 5 IO lines
No complicated communication interfacing required, all digital IO controlled
Good luck
Well, then I know its a software problem, as we have exactly the same setup.
Thanks for the thumbs up.
p.
edit: it was a software problem. i decided to control the multiplexer with pins 0 through 4, while simultaneously debugging via serial. :-/
Awesome. I bet that had interesting side effects.
Would you be able to elaborate on "hardwire" all the SCl lines and multiplex the SDA lines of the IMU with the MUX board referenced?
Hi @johnnyonthespot, I followed your advice and did harwiring of SCL lines and using MUX for SDL lines. It works for two I2Cs but as soon as I hardwire more than 2 SCL lines nothing works.
Any suggestions?
