I'm trying to connect 3 MPU9150 sensors to Arduino using I2C, but can't get it working. A single MPU9150 without Multiplexer works well. The multiplexer I use is CD4067BE. All resistors are 2.2k.
Since I can imagine that I made some mistake (I'm not good at electronics), I chose to ask a question here. What did I do wrong? Wrong Multiplexer maybe? Wrong wiring? It may be a programming mistake, it's my first attempt to write anything for arduino, but there isn't much to do wrong. I don't even try to read from 2nd and 3rd sensors. An attempt to test connection to the first one results in "MPU6050 connection failed".
#include "Wire.h"
#include "I2Cdev.h"
#include "MPU6050.h"
MPU6050 accelgyro;
int EN = 12;
int MA = 8;
int MB = 9;
int MC = 10;
int MD = 11;
int mux_id = 0;
int16_t ax, ay, az;
int16_t gx, gy, gz;
int16_t mx, my, mz;
void mux(int n) {
Serial.print("MUX: "); Serial.print(n); Serial.println(".");
digitalWrite(EN, LOW);
if(n%2==1) {
digitalWrite(MA, HIGH);
Serial.print(1);
digitalWrite(MA, LOW);
Serial.print(0);
if(n%4>1) {
digitalWrite(MB, HIGH);
Serial.print(1);
digitalWrite(MB, LOW);
Serial.print(0);
if(n%8>3) {
digitalWrite(MC, HIGH);
Serial.print(1);
digitalWrite(MC, LOW);
Serial.print(0);
if(n>7) {
digitalWrite(MD, HIGH);
Serial.print(1);
digitalWrite(MD, LOW);
Serial.print(0);
Serial.println("");
pinMode(EN, OUTPUT);
pinMode(MA, OUTPUT);
pinMode(MB, OUTPUT);
pinMode(MC, OUTPUT);
pinMode(MD, OUTPUT);
mux(0);
Wire.begin();
Serial.begin(38400);
Serial.println("Initializing I2C devices...");
accelgyro.initialize();
// verify connection
Serial.println("Testing device connections...");
Serial.println(accelgyro.testConnection() ? "MPU6050 connection successful" : "MPU6050 connection failed");
delay(2000);
// read raw accel/gyro measurements from device
accelgyro.getMotion9(&ax, &ay, &az, &gx, &gy, &gz, &mx, &my, &mz);
// display accel/gyro x/y/z values
Serial.print("(");
Serial.print(ax); Serial.print(",");
Serial.print(ay); Serial.print(",");
Serial.print(az); Serial.print(",");
Serial.print(gx); Serial.print(",");
Serial.print(gy); Serial.print(",");
Serial.print(gz); Serial.print(",");
Serial.print(mx); Serial.print(",");
Serial.print(my); Serial.print(",");
Serial.print(mz);
Serial.println("");
//mux_id = (mux_id + 1)%3;
//mux(mux_id);
