multiplexing voltage display
Hi all, simple design that i have planned: to display onto three (3) 7-segment LED displays. the voltage of a variable power supply from 1.5-22VDC.
first problem i am having is that the numbers displayed are inverted, that is from the display:
_ A
|| F, G, B
|. E, D, C, DP
for the digit '1' B and C should be lit, however, A, D, E, F, G, DP are lit instead.
trying to test this, i have been using a code that i found:
Using 2 7-segment displays with the 74HC595 shift registers
CC by-sa-nc 3.0
http://tronixstuff.wordpress.com
int latchpin = 8; // connect to pin 12 on the '595
int clockpin = 12; // connect to pin 11 on the '595
int datapin = 11; // connect to pin 14 on the '595
float b = 0;
int c = 0;
float d = 0;
int e = 0;
int speed = 300; // used to control speed of counting
int segdisp[10] = {
 3,159,37,13,153,73,65,27,1,9};
 pinMode(latchpin, OUTPUT);
 pinMode(clockpin, OUTPUT);
 pinMode(datapin, OUTPUT);
 //  Count up
 for (int z=0; z<100; z++)
   digitalWrite(latchpin, LOW);
   shiftOut(datapin, clockpin, LSBFIRST, 0); // clears the right display
   shiftOut(datapin, clockpin, LSBFIRST, 0); // clears the left display
   if (z<10)
     shiftOut(datapin, clockpin, LSBFIRST, segdisp[z]); // sends the digit down the serial path
     shiftOut(datapin, clockpin, LSBFIRST, 255); // sends a blank down the serial path to push the digit to the right
     digitalWrite(latchpin, HIGH);
   else if (z>=10)
     d=z%10; // find the remainder of dividing z by 10, this will be the right-hand digit
     c=int(d); // make it an integer, c is the right hand digit
     b=z/10; // divide z by 10 - the whole number value will be the left-hand digit
     e = int(b); // e is the left hand digit
     digitalWrite(latchpin, LOW); // send the digits down to the shift registers!
     shiftOut(datapin, clockpin, LSBFIRST, segdisp[c]);
     shiftOut(datapin, clockpin, LSBFIRST, segdisp[e]);
   delay(speed);
 delay(2000);
 //  Count down
 for (int z=99; z>=0; z--)
   if (z<10)
   else if (z>=10)
   delay(speed);
   delay(2000);
probably well known, counts from 0 through to 99 then backwards.
so, my first problem is i have the hardware set up correctly, so why are the numbers invertly lit?
Maybe the display is common anode/cathode instead of common cathode/anode (delete as applicable), really need a schematic and part numbers to be sure. As it lights the segments correctly (though inverted) I would think it's wired okay. Simple fix would be to invert the segment definitions from 3,159,37,13,153,73,65,27,1,9 to 252,96,218,242,102,182,190,228,254,246
Rather than sending a number, send the opposite of that number.
For example, instead of
Use
     shiftOut(datapin, clockpin, LSBFIRST, ~segdisp[z]); // sends the digit down the serial path
Beautiful. i didnt try the print the not number, because the first worked fine.
now that i have the physical printing semi-sorted, i moved onto the voltage calculation itself. it works perfectly fine, however, because i want to display to 0.1V, is there any method of 'rounding' that i could use to print a result (as seen by serial) of 2.55 to 2.6, and 2.54 to 2.5 for later integration onto the 7 segment displays?
here is the voltage snippit of coding
result smoothing: http://www.arduino.cc/en/Tutorial/Smoothing
Voltage calculation: http://arduinotronics.blogspot.com.au/2011/03/monitoring-voltage-of-dc-battery-supply.html
int VoltageIn = A5;
const int numReadings = 40;
int readings[numReadings];      // the readings from the analog input
int index = 0;                  // the index of the current reading
int total = 0;                  // the running total
int average = 0;                // the average
Serial.begin(9600); // initialize serial communication with computer:
  // initialize all the readings to 0:
  for (int thisReading = 0; thisReading < numReadings; thisReading++)
    readings[thisReading] = 0;
  total= total - readings[index];         // subtract the last reading:
  readings[index] = analogRead(VoltageIn);// read from the sensor:
  total= total + readings[index];         // add the reading to the total:
  index = index + 1;                      // advance to the next position in the array:
  if (index >= numReadings)               // if we're at the end of the array...
    index = 0;                            // ...wrap around to the beginning:
  average = total / numReadings;          // calculate the average:
  Serial.println(average);                // send it to the computer as ASCII digits
  delay(1);                               // delay in between reads for stability
int val = analogRead(average); // read the value from the sensor
float volts = (average * 0.021965811965812); // calculate the ratio
Serial.println("Volts:");
Serial.println(volts); // print the value in volts
Serial.println("average value");
delay(400);
note: the value or 0.0219... was calculated manually as a constant to alter the calculated value to the true voltage
Hi all,
i managed to (re) find the wording for code i was after.
here is my code thus far.
int VoltageIn = A5;
int latchpin = 8; // connect to pin 12 on the '595    GREEM
int clockpin = 12; // connect to pin 11 on the '595   BLUE
int datapin = 11; // connect to pin 14 on the '595    YELLOW
float b = 0;
int c = 0;
float d = 0;
int e = 0;
int speed = 500; // used to control speed of counting
int segdisp[10] = {
 252,96,218,242,102,182,190,228,254,246};
float volts = (average * 0.021965811965812 * 0.94104308390023); // calculate the ratio
Serial.println("");
Serial.println("");
int ones = int(volts);
int tenths = int((volts - ones) * 10);
Serial.println("voltage _test:");
Serial.println(ones);
Serial.println(tenths);
Serial.println("");
if (volts < 10)
  int tens = 0;
  shiftOut(datapin, clockpin, LSBFIRST, segdisp[tenths]); // clears the right display
  shiftOut(datapin, clockpin, LSBFIRST, segdisp[ones]); // clears the left display
  shiftOut(datapin, clockpin, LSBFIRST, segdisp[tens]); // clears the left display
else if (volts >= 10)
  int tens = int(volts / 10);
  int ones = int((volts - tens * 10));
  int tenths = int((volts - tens * 10 - ones) * 10);
delay(5);    // to allow for a reset time
and i two questions. when writing to the '595s, there is a very annoying flicker between each value and re-print onto the 7 segments.
is there any way that that could be reduced?
and second. the relationship between the calculated voltage and true voltage should be a linear relationship, yes? i only ask because mine is not, i can have 1.2V calc == 1.2V measured, however bumping it up to 7.2V true gives me a fluctuating 7.3 - 7.4V measured
Because your code does that.
What you should have done is to calculate the right segment information, send them to the hc595, and then latch. This will cause the display to be updated instantaneously, no flickering at all. Like this:
  //get the right number to volts
  unsigned short voltsx10 = volts * 10; //convert volts to a fixed point integer
  tenths = voltsx10 % 10; voltsx10 /= 10;
  ones = voltsx10 %10; voltsx10 /=10;
  tens = voltsx10 %10;
  //check for blanks
  if (tens==0) tens = BLANK;
  if ((tens == BLANK) || (ones == 0) ones = BLANK;
This will blank out leading zeros and will not cause any flickering.
You really should avoid the use of floating point math also.
Might be a good idea to put the latch pin high every once in a while, too...
Latch should be a short pulse after the data is in place.
