Multiplexing while holding a value
Hello,
I was making a program for surveillance of a power part in an application. It should display the voltage and run a temperature control fan. The voltage is displayed on a 7-segment display, 3 digits, so it obviously is multiplexed.
The code seems to work like a charm so far, only problem is that the voltage source is quite jittery as I lately found out. The voltmeter though updates with the multiplexing frequency, which annoys the hell out of me.
I have tried some approaches, like delays in the voltage()-function or for-loops with multiple iterations at different parts in the code. But all has so far either screwed up the voltage reading or the multiplexing.
Has anyone an idea on how I could get the update rate down? About 2-4 times per second or so?
Code is provided below, any help is appreciated.
Thanks in advance,
Cheers, Ivo
//beginning of code
int pinA0=A0;
int disp1=1;
int disp2=2;
int disp3=3;
int segA=5;
int segB=6;
int segC=7;
int segD=8;
int segE=9;
int segF=10;
int segG=11;
int segDP=12;
int temp=A1; // remap to A13 on atTiny167
int fan=4; // remap to 14 on atTiny167
  pinMode(disp1, OUTPUT);
  pinMode(disp2, OUTPUT);
  pinMode(disp3, OUTPUT);
  pinMode(segA, OUTPUT);
  pinMode(segB, OUTPUT);
  pinMode(segC, OUTPUT);
  pinMode(segD, OUTPUT);
  pinMode(segE, OUTPUT);
  pinMode(segF, OUTPUT);
  pinMode(segG, OUTPUT);
  pinMode(segDP, OUTPUT);
  pinMode(pinA0, INPUT);
  pinMode(temp, INPUT);
  pinMode(fan, OUTPUT);
int voltage() {
  /*measures the voltage on pin A0 and returns a float value from 0 to 30. Meant
  for a voltage divider factor 6 on the input. */
  int input=analogRead(pinA0);
  float voltage=(input /20.48)*6;
  return voltage;
void display(int digit) {
  /*Takes a single digit int and sets the according segments of the display*/
  switch (digit) {
    case 0:
    digitalWrite(segA, LOW);
    digitalWrite(segB, LOW);
    digitalWrite(segC, LOW);
    digitalWrite(segD, LOW);
    digitalWrite(segE, LOW);
    digitalWrite(segF, LOW);
    digitalWrite(segG, HIGH);
    case 1:
    digitalWrite(segA, HIGH);
    digitalWrite(segD, HIGH);
    digitalWrite(segE, HIGH);
    digitalWrite(segF, HIGH);
    case 2:
    digitalWrite(segC, HIGH);
    digitalWrite(segG, LOW);
    case 3:
    case 4:
    case 5:
    digitalWrite(segB, HIGH);
    case 6:
    case 7:
    case 8:
    case 9:
void callupDigit1(int y) {
  //Digit 1
  digitalWrite(disp1,HIGH);
  digitalWrite(disp2,LOW);
  digitalWrite(disp3,LOW);
  digitalWrite(segDP,HIGH);
  display(y);
void callupDigit2(int y) {
  //Digit 2
  digitalWrite(disp2,HIGH);
  digitalWrite(segDP,LOW);
  display(y);
void callupDigit3(int y) {
  //Digit 3
  digitalWrite(disp1,LOW);
  digitalWrite(disp3,HIGH);
  display(y);
void checkTemp() {
  int read = analogRead(temp);
  if (read >= 711) {
    digitalWrite(fan, HIGH);
  else if (read <= 518) {
    digitalWrite(fan, LOW);
  checkTemp();
  int x = voltage();
  int y = x%10;
  callupDigit3(y);
  delay(5);
  x = x/10;
  y = x%10;
  callupDigit2(y);
  delay(5);
  x=x/10;
  y=x;
  callupDigit1(y);
  delay(5);
//end of code
Program.ino (4.04 KB)
Please edit your post to include code-tags, see How to use the forum.
And I think you can make it yourself a HECK lot easier by just using the sevenSeg library :wink:
I would use a timer interrupt to drive the LEDs. Then you can use the main loop to do whatever processing on voltages you need.
Or use a MAX7219 to control the display, let it mux the display at 800 Hz for you. Then every 250-500mS you just send it whatever you want displayed.
septillion:
Thanks for pointing that out, I will do so. Sorry I have missed that, I am new to the forum.
Also, just to inform whoever might read this, I could fix the problem in the mean time.
I have not used the sevenSeg library, as I was not too familiar with the Arduino libraries just yet. I also need the code to be as small as possible.
I also had to avoid external components for this project.
Just so others can benefit from my errors, I will briefly explain what I changed:
In the loop, the different digits are determined by modulo division. I tried a sample and hold by sort of repeating that process multiple times, but that would always repeat the division and screw up the output.
In the new version, I now determine the digits outside the for-loop and then displayed several times. The sampling time is then (times of repeat)(total of delay)=3515=525ms in this case.
See the loop function for reference.
But thanks to everybody who offered help
Greets, Ivo
  checkTemp();
  int x = voltage();
  int y3 = x%10;
  x = x/10;
  int y2 = x%10;
  x=x/10;
  int y1 = x;
  for (int i=0; i<35; i++) {
    callupDigit3(y3);
    delay(5);
    callupDigit2(y2);
    delay(5);
    callupDigit1(y1);
    delay(5);
Perlmarmelade:
With your implementation, that's nowhere going to be the case...
Well, small enough for me, got me one less header.
Then your definition of small is pretty large :stuck_out_tongue:
What do you mean "one less header"?
Just mind your reads that update the write variable.
If you want to update a reading less frequently, then obviously do that. Although you could make use of those frequent readings to average them out and only periodically print to get a smoother reading.
not sure how Arduin does it, but if I don't use a library, it should not be included into my code?
The code fits my use anyways.
Perlmarmelade:
So? Using your own code vs a library doesn't make it automatically small... In this case, on the contrary. The library is better written and you only have to include it and write a hand full of lines of code to do the same. Smaller code, smaller upload size.
Perlmarmelade:
Of course, that's to no surprise. It's a very small task / sketch for the Arduino...
