I have a variable that is sometimes greater than 32,767 so I can't use int type. Instead I use long, but I get a strange error when multiplying with the long variable.
For example, my variable is called 'product' and at some point I set product = 1087 * 44. I expect to get product = 47828 from this but instead I get product =-17708!
What is going on here?
Here is a sample code that shows the problem I'm encountering:
long product = 0;
void setup(){
void loop(){
product = 1087*44; //this should return 47828 but instead it returns -17708
Serial.print("1087 * 44 = ");
Serial.println(product);
delay(5000);
If I do it this way I get the correct result however:
long product = 0;
void setup(){
void loop(){
product = 1087;
Serial.print(product);
Serial.print(" * ");
Serial.print(44);
product=product*44;
Serial.print(" = ");
delay(5000);
Am I just using incorrect syntax when I write product=1087*44; ?
