multiplier
Please explain the voltage requirements for the lens. Have you a specification or datasheet for the lens?
The +9V is where you connect the incoming power. You need to provide 9V or a little more at 250mA. You can use the same supply to power the Arduino if the supply can handle the extra current for the Arduino + anything running from its 5V supply.
dc42:
Please explain the voltage requirements for the lense. Have you a specification or datasheet for the lense?
The lens operates between 2-3kV, but we aim to be able to control it with a system.
Can the roles of the resistors prior to the op-amp and the role of the op-amp be explained in more detailed?
The resistors coming off the HVM i am assuming is to make safe the connection back to arduino ground?
(sorry im quite a beginner trying to attempt a complex project)
domo:
The 10K resistor keeps the op amp input at ground potential while the Arduino is initializing. Without it, the voltage on the op amp input would drift to +5v because of the input bias current of the amplifier, causing the unit to produce the maximum output voltage.
The 100K resistor and 0.1uF capacitor smooth the PWM to a steady voltage.
The 100M and 100K resistors between the HV output and ground form a voltage divider to convert 0 - 5kV to 0 - 5V, allowing the Arduino to measure the output voltage.
Also the resistor and transistor after the op-amp i presume is to control input voltage to the HVM?
This was the suggested circuit for using the HVM,
I dont understand why use a buffer?
  1. You need a buffer because an Arduino can only supply 40mA per output pin, whereas the 5V version of the HV multiplier requires up to 250mA.
  2. However, there are very few op amps that can supply as much as 250mA output current. That is why I suggested using an op amp and NPN transistor as the buffer.
  3. You cannot connect the input of the buffer direct to an Arduino output pin, because the Arduino does not have an internal DAC to drive any output pins with a variable voltage, and you must not try to drive the HV multiplier with PWM. That is why I included the RC network at the input to the buffer.
dc42:
Why can the HV not be driven by the PWM?
PWM works when there is some averaging mechanism to smooth out the PWM. Electronic assemblies generally do not have this averaging mechanism. If you try to feed them with PWM'd power, they will generally not behave in the way you want, and draw high peak currents which are likely to damage them and/or the circuits driving them.
Some electronic assemblies provide a a separate PWM input. The HV multiplier you are planning to use does have the option of an external input for turning off the HV supply, but it is clear from the datasheet that this input is not intended for PWM.
dc42:
10-bit: 12-bit external DAC + possible op amp + emitter follower.
11-bit: 12-bit external DAC + possible op amp + emitter follower + 12-bit external ADC.
The "possible op amp" would be needed unless you are using the 5V version and it is lightly loaded.
When using a DAC, would that be connected to the Arduino output, and then to the rest of the circuit?
and im guessing the ADC will come before the HVM module? any examples on how to adjust the circuit, or what to add in to make these effective changes?
Also the op-amp i have, has 8 pins but only 3 is needed for the circuit (im presuming) but would i need to ground it too?
Also if another Arduino board was to be used (such as Due, which has a DAC) does that remove the need for an external DAC?
domo:
The DAC would be connected to the Arduino via SPI or I2C depending on which DAC you used. Its output would feed the non-inverting input of the op amp, in place of the R-C filter.
domo:
Yes. AFAIK the Due is still the only Arduino board that has an integral DAC.
What i dont understand is, if there is a DAC, then hasnt the output become analogue? where does it turn dc again?
When i connect up the circuit, it does not seem to work. I am inputting the output
Which circuit have you built? I suggest you also post a photo of your wiring.
I have built the buffer without the transistor system and the external secondary voltage input.
If you build the circuit as I described it, then I will try to help you get it working. If you leave bits out, you're on your own.
photo1 just shows the wiring after op-amp and before HVM.
When i attempt to put in a second voltage input it doesn't work, therefore i tried to test the circuit by building whats on photo 2, which works but the output is not ideal.
