I want to multiply somehow 32bit and 64bit numbers. I know that arduino uno doesnt support bigger number than 64bit, so Im looking for another way how to do it.
My idea was to store them into arrays and mutiply them but result is really not very accurate
septillion:
I think it depends a bit on what you want to do with it. Do you actually need to store the 96 bit number? Or are you going to divide it again?
And yeah, there are some other implementations
Well, I need to store him in char array, not in EEPROM, just char array, then I want to send it via wireless module. Module works great so there is not issue, but I need to somehow multiply it and on my receiving site I need to divide it
And I dont want to use BigNumber by nick because it takes a lot of space
uint64_t  a_lo = (uint32_t)a;
uint64_t  a_hi = a >> 32;
uint64_t  b_lo = (uint32_t)b;
uint64_t  b_hi = b >> 32;
uint64_t  a_x_b_hi = a_hi * b_hi;
uint64_t  a_x_b_mid = a_hi * b_lo;
uint64_t  b_x_a_mid = b_hi * a_lo;
uint64_t  a_x_b_lo = a_lo * b_lo;
uint64_t  carry_bit = ((uint64_t)(uint32_t)a_x_b_mid +
            (uint64_t)(uint32_t)b_x_a_mid +
            (a_x_b_lo >> 32) ) >> 32;
uint64_t  multhi = a_x_b_hi +
          (a_x_b_mid >> 32) + (b_x_a_mid >> 32) +
          carry_bit;
return multhi;
Of course you can work around it. You could also make an assembly implementation (it's nothing more then extending 16-bit etc) but I doubt it's a very effective uC solution (at least on a 8-bit and/or without hardware multiply...)
LadIQe:
its for security purpose Im using random 32bit and 64bit codes for IDs, cipher etc, and one step is multiply 32 and 64 bit numbers
So this is an xyproblem: you want to implement some sort of security. You imagine multiplication is how
to do this (it isn't - you need encryption or authentication or both perhaps?)
So explain what you are really trying to achieve...
as I said, im using random 32bit and random 64bit numbers, than i want to multiply them, use AES encryption, send it, decrypt it on the other side and divide, get IDs and thats all
