multiplying ??
hi , ive only recently started with the arduino , seemed very easy untill i had to start using other people libraries and then this . Im trying to multiply rpm by 2 but cannot get it working its actually part of a much bigger sketch but was trying to work it out on this small simplified one first .How the sketch is this does multiply by 2 but only to the closest 514 . Any help would be appreciated
#include <Arduino.h>
#include <Wire.h>
#include <OBD.h>
COBDI2C obd;
obd.begin();
  // initiate OBD-II connection until success
  while (!obd.init());
int rpm;
int rpma=(rpm*2);
if (obd.read(PID_RPM,rpm));
Serial.print(rpm);
Serial.print("\t");
Serial.println(rpma);
delay (1);
You are re-initializing RPM every time you run loop, move the: int rpm; int rpma; to Setup(), and then in the loop(), just have rpma=rpm*2;
Also make sure you aren't going to hit max int (about 32000)
sp. "outside of setup() and loop()"
If you move them to setup(), they won't be in scope in loop()
thanks awol , its working well now .
