Multitasking while one loop takes more time then second loop interval
So I'm trying to keep my stepper motor rotate at a constant speed, and read the temperature. My idea was to use a moving event concept using millis(). (Just an idea code below)
const unsigned int motorInterval = 6;
const unsigned int tempInterval = 50;
unsigned long motorPreviousTime = 0;
unsigned long tempPreviousTime = 8;
unsigned long currentTime = 0;
void loop(){
currentTime = millis();
if( currentTime - tempPreviousTime >= tempInterval){
    ;measure temp + print to lcd
    tempPreviousTime = currentTime;
if( currentTime - motorPreviousTime >= motorInterval){
    ;do single step
    motorPreviousTime = currentTime;
The problem is to keep my motor rotate 50 rpm, I need to do a single step every 6 ms. And the temperature measurement takes 850 ms. At this point, my program fails. Temperature measurement
overlaps motor stepping causing much slower rotation (motor acts weird).
I use ds18b20 sensors with one wire interface and DallasTemperature.h library. Stepper motor with A4988 driver.
So you need a non-blocking way to read temperature.
you could step the motor in an interrupt triggered every 6 msec
gcjr:
Yeah, that should solve the issue !
it really takes close to a second to read a temperature sensor?
gcjr:
Yes, if you use the most commonly used library, which is blocking. The temp IC is horribly slow. There are much better temperature sensors on the market.
