Multitasking with TUSB2036 Hub IC interfaced with Arduino Mega ADK
Hello,
At the moment, I am engaged in operating a flash drive, a Dot matrix printer and a keyboard using Hub IC which in turn interfaced with Arduino Mega ADK. I have declared in the following form:
USB Usb;
USBHub Hub(&Usb);
HIDBoot<HID_PROTOCOL_KEYBOARD> HidKeyboard(&Usb); ------->Keyboard
KbdRptParser Prs;
BulkOnly bulk(&Usb); ---------->Flash drive
UsbFat key1(&bulk);
FatFile file;
File file2;
File file3;
USBH_MIDI Midi(&Usb);-----------> Printer
what I have observed is keyboard and flash drive interfacing is working fine, but the printer is not responding.
rcode1 = Midi.SendRawData(PRINTER_CLEAR_COMMAND_LEN, (uint8_t*)byte_array);
if(rcode1)
Serial.println("rcode1 Failed");
return;
}else{
Serial.println("Issued the clear command.");
//delay(200);
return;
when I have called the printer to function, it is indicating "rcode1 Failed".(USB_Host_Shield_2.0 on Github).
I am requesting you to please help me in this regard.
Thank You,
Vamshi
Do you actually own a printer that talks MIDI?
No, I am using EPSON LQ-310 Dot matrix printer.
As it works based on bulk transfer, I used MIDI library files to trigger the printer.
Also printer alone works fine with MIDI libraries.
Post a complete wiring diagram and your complete code.
Also describe what you're trying to achieve.
