multitasking
hi
i am working on a project where in i need to display a timer counter for 60 sec in left side of the display, and in the other half of the display i need to display a scrolling message. the timer counter will run continuously irrespective of message displayed in the other half of the display.
after 60 sec i need to clear the entire display.
i am using LED P10 32*16 display, with red color.
i am using DMD2 library to do the above task.
i am able to do the task of displaying the counter and message respectively but the counter gets delayed due to the long message.
#include <SPI.h>
#include <DMD2.h>
#include <fonts/SystemFont5x7.h>
#include <fonts/Arial14.h>
#include <fonts/Droid_Sans_24.h>
#include <fonts/Droid_Sans_16.h>
// Set Width to the number of displays wide you have
const int WIDTH = 1;
const int COUNTDOWN_FROM = 0;
int counter = COUNTDOWN_FROM;
const uint8_t *FONT = SystemFont5x7;
const uint8_t *FONT2 = SystemFont5x7;
const char *MESSAGE = "GOA  ";
SoftDMD dmd(WIDTH,1);  // DMD controls the entire display
DMD_TextBox box(dmd, 0, 1);
DMD_TextBox box1(dmd,11,1);  // "box" provides a text box to automatically write to/scroll the display
long previousMillis = 0;        // will store last time box was updated
long interval = 1000;
unsigned long previousMillis2 = 0;
long interval2 = 1000;
void scroll();
void run_counter();
// the setup routine runs once when you press reset:
  dmd.setBrightness(255);
  //dmd.selectFont(FONT);
  dmd.begin();
  if(currentMillis - previousMillis > interval) {
    if (counter <60)
      box.print(counter);
      box.println(F(""));
      counter++;
      box1.clear();
      counter = 0;
      box.print(counter);
      // box.println(F(""));
      dmd.clearScreen();
  if(currentMillis - previousMillis2 >= interval2)
    previousMillis2 = currentMillis;  // Remember the time
     dmd.selectFont(FONT2);
     const char *next = MESSAGE;
     while(*next) {
     Serial.print(*next);
     box1.print(*next);
     next++;
please help
Don't do that then.
You may have to break this loop into a third timer with a 500ms interval.
how to break it into 500ms??
gourish:
"Delay" pauses your program. Take a look at this
https://www.arduino.cc/en/Tutorial/BlinkWithoutDelay
The demo Several Things at a Time is an extended example of BWoD and illustrates the use of millis() to manage timing without blocking. It may help with understanding the technique.
...R
ok i removed the delay but then my message is scrolling to fast.
gourish:
In that case check the time using the millis() function. You can slow down the message output without actually stopping your program,
i tried using millis() but the result is the same.
i think i need to change the way i am scrolling the message.
while(*next) {
box1.print(*next);
next++;
is there any other method in which i can scroll the message the way i want?
gourish:
See response #4 by Robin2, follow the link and read it thoroughly.
i read it but it gave me idea on how to do this multitasking with led and servo that is fine.
but the same thing i am not able to do with the scrolling message.
and i didn't find anyone doing this stuff like count up timer with a scrolling message, were the message will have its own speed and counter will run as a clock.
There is not much difference between having an LED go on or off, or moving a message by one character.
gourish:
In summary using the BlinkWithoutDelay principle
start of loop()
  if the LED state change state period has passed
    change the LED state
    save the time
  end if
  if the message scrolling period has passed
    scroll the message
    save the time
  end if
end of loop()
start of loop()
save the time
end if
scroll the message
save the time
end if
end of loop()
after making this changes i am only able to print the counter the scrolling message is not printing.
char MESSAGE = "GOA  ";
  dmd.begin();
ss  unsigned long currentMillis = millis();
 if((counter <60)&&currentMillis - previousMillis > interval) {
      box.print(counter);
      box.println(F(""));
      counter++;
 if((counter <60)&&(currentMillis - previousMillis2 > interval2))
      box1.print(*next);
      *next++;
 if(counter == 60)
         dmd.clearScreen();
If you comment out the counter code does the scrolling message work ?
Before your IF statements print the variables used in the IF.
You will then see why the IF does or does not do what you are expecting.
this method is not helping me m trying from 4 hours now i came up with new method it is helpful but the message scrolls too fast.
#include <mthread.h>
#include <SPI.h>
#include <DMD2.h>
//int len = strlen(MESSAGE);
// Our custom Thread:
class FooThread : public Thread
public:
    FooThread(int id);
protected:
    bool loop();
private:
    int id;
    const char MESSAGE = "I am in VASCO DA GAMA, GOA";
FooThread::FooThread(int id)
    this->id = id;
bool FooThread::loop()
    // Die if requested:
    if(kill_flag)
        return false;
    // Print the status message:
    Serial.println(id);
    if((id==1)&&(counter <10))
       Serial.println(counter);
       box.print(counter);
       box.println(F(""));
       counter++;
    else if((id ==3)&&(counter <10))
     const char *next = "MESSAGE TO THE TRAVELER";
     while(*next) {
     box1.print(*next);
     sleep(3);
     next++;
     sleep_milli(100);
    else if (counter >=10)
      dmd.clearScreen();
      kill(true);
    // Sleep for one second:
    sleep(1);// sleep for one second
    return true;
     main_thread_list->add_thread(new FooThread(3));
     main_thread_list->add_thread(new FooThread(1));
     dmd.begin();
gourish:
That's not very long ...
...R
There should be no need to use yet another library to do something fundamentally simple such as timing 2 events independently
Can you please answer the question that I posed in reply #13 with respect to your code in reply #12
I see that you declare MESSAGE as a char
How many characters can a simple char variable hold ?
try reverting everything you did, then use the neotimer library
link
search neotimer on libraries and install it
devcoder:
Why not just use millis() ?
...R
