Hi everyone,
i have a basic (very basic) use case with an arduino and a led strip. i'll try to explain it very simply :
i have a 5meters led strip with 300 leds/pixels connected to my arduino uno, i created a function to light leds one after the other at a specific pace :
void startPace(int speed, int green, int red, int blue){
for (int i=0; i<300; i++){
FastLED.clear();
leds[i] = CRGB(green,red,blue);
FastLED.show();
delay(100); // for the fotum each 100ms i light the next led, but in the code it depends on a speed
FastLED.clear();
FastLED.show();
my need, is to fire a first color, and 10 seconds after fire another, so naively i did this:
startPace(3, 255,0,0);
delay(10000);
startPace(6,0,255,0);
doing this, i expected to fire a green led at 3 kph and 10 seconds after a red one at 6kph so that the red one catches the green one. but i think everyone guessed the problem, the red never catches the green since the red fires only 10 seconds after the green finishes the 5 meters length.
i understand that c++ is not java but is it possible to code this use case with an arduino ?
You have to take things one step at a time with no for() loop inside your function. This will allow other things to get done. You also can not use delay() since nothing else happens while it is executing. Look at the Blink without Delay example in the IDE (File->examples->02.digital->Blink Without Delay)
And then you get something like this:
#include <FastLED.h>
// How many leds in your strip?
#define NUM_LEDS 300
#define DATA_PIN 3
#define CLOCK_PIN 13
unsigned long startTime;
unsigned long lastTime;
bool redRunning = false;
const unsigned long redDelay = 10000; // 10s delay for red to start
// Define the array of leds
CRGB leds[NUM_LEDS];
int greenIdx = 0;
int redIdx = 0;
FastLED.addLeds<NEOPIXEL, DATA_PIN>(leds, NUM_LEDS); // GRB ordering is assumed
Serial.println("ready");
startTime = millis();
unsigned long currentTime = millis();
if ( currentTime - startTime >= redDelay ) {
redRunning = true;
greenPace();
if ( redRunning ) {
redPace();
void greenPace() {
const byte green = 255;
const byte red = 0;
const byte blue = 0;
const unsigned long interval = 100;
static unsigned long lastTime;
if ( millis() - lastTime >= interval ) {
// time to move led
lastTime = millis();
leds[greenIdx] = CRGB(0, 0, 0);
greenIdx = (greenIdx + 1) % NUM_LEDS;
leds[greenIdx] = CRGB(green, red, blue);
FastLED.show();
void redPace() {
const byte green = 0;
const byte red = 255;
const unsigned long interval = 50;
// time to move led
leds[redIdx] = CRGB(0, 0, 0);
redIdx = (redIdx + 1) % NUM_LEDS;
leds[redIdx] = CRGB(green, red, blue);
FastLED.show();
well i didn't really dig the problem in java, but i would take the road of threads if i wanted to execute parallel behaviours in java. what i am saying might be stupid
well obviously no, and i don't see the point of your questions besides humiliating me, i am not very good at conding and i am trying to learn, you are not very helpful so i suggest that we stop here. thank you
You brought up Java, there has to be a reason, probably because you know Java. The question was legit, if you can do this in Java, you certainly can do this in C++.
Major OSes support threading at the OS level and major JVMs rely on the default platform threads library. So it's up to the OS to schedule threads on multiple or one single core.
The challenge would be more on handling the concurrent use of resources...
There is no real point going down that route. it does not help OP nor do I see what's the value.
The code does have a variable delay already so that both threads progress at variable speed through the counting. That was the intent of the code - two things progressing in pseudo parallel at their own speed.
if they were to access shared resources then you would need to serialize access to such shared resources. Java has built-in support to prevent collisions over resources (the synchronized keyword). Semaphore, wait etc can be used as well.
