After extensive stress tests and after months of use in production, I’m happy to announce MultiTrans, an implementation of a multi channel transceiver. Find MultiTrans in the Arduino library manager or in the GitHub repo feklee/multitrans.
New in version 1.2 is binary communication, i.e. sending and receiving messages that may include the null character.
I’m happy to answer any questions!
Features:
Transceiver: Transmit and receive simultaneously via a single pin. (No clock line needed.)
Multi channel: Multiple pins can transceive simultaneously.
Collision detection: One pin can start sending without worrying if the other side is sending as well. Collisions are automatically detected and circumvented. No information is lost.
Maximum uni-directional data rates on an Arduino Uno / Pro Mini:
Communication with one peer: 12 kbit/s
Communication with four peers: 3 kbit/s
Bi-directional data rates are a little less than half of the above rates in each direction.
Limitations: -
Buffers:
The buffer on the transmitting end can contain 256 bits at the most. For each character, 21 bits are necessary. This equates to 12 characters.
The buffer on the receiving end can only contain up to 255 pin change events.
Flushing the buffer on the receiving end takes some time.
The system is thus best used for short bursts of data with sufficient idle time in between. -
No built-in error checking. You may want to implement your own error checking, to take care of:
If you have a flaky connection between the Arduinos, for example due to bad electrical contacts, then bits may get lost.
Theoretically, i.e. if timing is perfectly right, the collision detection built into MultiTrans may fail resulting in bit loss.
It only works with AVR based Arduinos. In fact, code so far has only been tested with the Arduino Pro Mini and the Arduino Uno.
Timers are occupied:
8-bit Timer/Counter2 (TC2), for transmitting
16-bit Timer/Counter1 (TC1), for receiving
Examples:
Simple: bi directional communication between two Arduinos
Triangle: Arduinos communicating in a triangle
Stress test (advanced): testing maximum and minimum data rates with five Arduinos all communicating simultaneously
