multy rotari encodeur
bonjour
j'aurai besoin de faire fonctionner 3 codeur rotatif type LPD3806 avec mon arduino
ci dessou le code utiliser
// definition des constanteet variable
volatile unsigned int temp, counter = 0; //This variable will increase or decrease depending on the rotation of encoder
float LONGEUR1 ; // longeur du poin xa
float LONGEUR2 ; //longeur du poin xb
float LONGEUR3 ; // longeur du poin xc
  Serial.begin (9600);
  pinMode(2, INPUT_PULLUP); // internal pullup input pin 2
  pinMode(3, INPUT_PULLUP); // internal pullup input pin 3
  pinMode(4, INPUT_PULLUP); // internal pullup input pin 4
  pinMode(5, INPUT_PULLUP); // internal pullup input pin 5
  pinMode(6, INPUT_PULLUP); // internal pullup input pin 6
  pinMode(7, INPUT_PULLUP); // internal pullup input pin 7
  //Setting up interrupt
  //A rising pulse from encodenren activated ai0(). AttachInterrupt 0 is DigitalPin nr 2 on moust Arduino.
  attachInterrupt(0, ai0, RISING);
  //B rising pulse from encodenren activated ai1(). AttachInterrupt 1 is DigitalPin nr 3 on moust Arduino.
  attachInterrupt(1, ai1, RISING);
  attachInterrupt(2, ai2, RISING);
  attachInterrupt(3, ai3, RISING);
  attachInterrupt(4, ai0, RISING);
  attachInterrupt(5, ai1, RISING);
  // Send the value of counter
  if ( LONGEUR1 != temp ) {
    Serial.println (LONGEUR1);
    Serial.println (LONGEUR2);
    Serial.println (LONGEUR3);
    temp = LONGEUR1;
void ai0() {
  // ai0 is activated if DigitalPin nr 2 is going from LOW to HIGH
  // Check pin 3 to determine the direction
  if (digitalRead(3) == LOW) {
    LONGEUR1++;
    LONGEUR1--;
void ai1() {
  // ai0 is activated if DigitalPin nr 3 is going from LOW to HIGH
  // Check with pin 2 to determine the direction
  if (digitalRead(2) == LOW) {
    LONGEUR1--;
    LONGEUR1++;
void ai2() {
  if (digitalRead(5) == LOW) {
    LONGEUR2--;
    LONGEUR2++;
void ai3() {
  if (digitalRead(4) == LOW) {
    LONGEUR2++;
    LONGEUR2--;
quelqu’un peu indiquer mon erreur svp
killino:
Oui... you posted in French in the English forum, without reading the forum rules...
Poster en français dans le forum français et lire le Règle du Forum (ou poster ? Quelles informations fournir ?comment poster du code ?.....).
En l'état ce fil de discussion est un bon candidat pour la poubelle.....
