Hi Gang
I’m posting in the help that someone can offer me some assistance with the basics of getting timer based interrupts working on the Mega2560 board.
My longer term aim is to have Timer0 (8 bit) counting an external 32.768KHz clock and dividing it by 256 through calling the ISR every 256 external pulses (128 times per second).
However, due to some spectacular Muppetry, I can’t get even a basic ISR to run. Here’s the code I would like help with:
#define ledPin 13
pinMode(ledPin, OUTPUT);
// initialize Timer1
noInterrupts(); // disable all interrupts
TCCR1A = 0;
TCCR1B = 0;
TCNT1 = 0;
OCR1A = 31250; // compare match register 16MHz/256/2Hz
TCCR1B |= (1 << WGM12); // CTC mode
TCCR1B |= (1 << CS12); // 256 prescaler
TIMSK1 |= (1 << OCIE1A); // enable timer compare interrupt
interrupts(); // enable all interrupts
ISR(Timer1_COMPA_vect) // timer compare interrupt service routine
Serial.println("Inside ISR");
digitalWrite(ledPin, digitalRead(ledPin) ^ 1); // toggle LED pin
Serial.println("Inside Main Loop");
delay(20000);
All I see in the serial monitor is the text output from the main loop and no activity on pin 13.
Can anyone (gently) point out what’s going on here?
Thank you,
Mark.
