Music Maker Shield - playing MP3s on a timer
This is the first thing I've managed to program since BBC Basic in the 1980s...
We are making a lure for birdcalls, to encourage rare birds to nest in a protected area. It needs to play an mp3 (LT2.mp3) file ten times, three times a day, then go to sleep the rest of the time (it will be connected to a 12v battery with a step down)
We are using an Arduino Uno, a Adafruit Music Maker shield and a DS3231 breakoutboard.
I think I have the code almost right, but when I put in the command on line 96; it doesn't play the mp3! (In this sketch, I have set it to play once at one minute so I could test whether it worked or not) Any hints or advice on what I am missing would be hugely appreciated!
 * I based this on this sketch which used a datalogger
 * Link To Tutorial http://www.thearduinomakerman.info/blog/2018/1/24/guide-to-arduino-sleep-mode
 * Link To Project   http://www.thearduinomakerman.info/blog/2018/2/5/wakeup-rtc-datalogger
 * I am trying to get Arduino to play an Mp3 ten times, three times a day, and go to sleep the rest
 * of the time.
#include <avr/sleep.h>//this AVR library contains the methods that controls the sleep modes
#define interruptPin 2 //Pin we are going to use to wake up the Arduino
#include <DS3232RTC.h>  //RTC Library https://github.com/JChristensen/DS3232RTC
#include <Adafruit_VS1053.h>
#include <SPI.h>        //SPI library for the sd breakout board. Part of the Arduino IDE
#include <SD.h>         //SD library for the sd breakout board. Part of the Arduino IDE
//RTC Module global variables
const int time_interval=1;// Sets the wakeup interval in minutes
// These are the pins used for the music maker shield
#define SHIELD_RESET  -1      // VS1053 reset pin (unused!)
#define SHIELD_CS     7      // VS1053 chip select pin (output)
#define SHIELD_DCS    6      // VS1053 Data/command select pin (output)
// These are common pins between breakout and shield
#define CARDCS 4     // Card chip select pin
// DREQ should be an Int pin, see http://arduino.cc/en/Reference/attachInterrupt
#define DREQ 3       // VS1053 Data request, ideally an Interrupt pin
Adafruit_VS1053_FilePlayer musicPlayer =
  // create breakout-example object!
  //Adafruit_VS1053_FilePlayer(BREAKOUT_RESET, BREAKOUT_CS, BREAKOUT_DCS, DREQ, CARDCS);
  // create shield-example object!
  Adafruit_VS1053_FilePlayer(SHIELD_RESET, SHIELD_CS, SHIELD_DCS, DREQ, CARDCS);
  Serial.begin(115200);//Start Serial Comunication
  pinMode(LED_BUILTIN,OUTPUT);//We use the led on pin 13 to indecate when Arduino is A sleep
  pinMode(interruptPin,INPUT_PULLUP);//Set pin d2 to input using the buildin pullup resistor
  digitalWrite(LED_BUILTIN,HIGH);//turning LED on
  // initialize the alarms to known values, clear the alarm flags, clear the alarm interrupt flags
    RTC.setAlarm(ALM1_MATCH_DATE, 0, 0, 0, 1);
    RTC.setAlarm(ALM2_MATCH_DATE, 0, 0, 0, 1);
    RTC.alarm(ALARM_1);
    RTC.alarm(ALARM_2);
    RTC.alarmInterrupt(ALARM_1, false);
    RTC.alarmInterrupt(ALARM_2, false);
    RTC.squareWave(SQWAVE_NONE);
     * Uncomment the block block to set the time on your RTC. Remember to comment it again
     * otherwise you will set the time at everytime you upload the sketch
     /* Begin block
     tmElements_t tm;
    tm.Hour = 00;               // set the RTC to an arbitrary time
    tm.Minute = 00;
    tm.Second = 00;
    tm.Day = 4;
    tm.Month = 2;
    tm.Year = 2018 - 1970;      // tmElements_t.Year is the offset from 1970
    RTC.write(tm);              // set the RTC from the tm structure
     Block end * */
     time_t t; //create a temporary time variable so we can set the time and read the time from the RTC
    t=RTC.get();//Gets the current time of the RTC
    RTC.setAlarm(ALM1_MATCH_MINUTES , 0, minute(t)+time_interval, 0, 0);// Setting alarm 1 to go off at 1 minutes
    // clear the alarm flag
    RTC.alarm(ALARM_1);
    // configure the INT/SQW pin for "interrupt" operation (disable square wave output)
    // enable interrupt output for Alarm 1
    RTC.alarmInterrupt(ALARM_1, true);
 delay(5000);//wait 5 seconds before going to sleep. In real scenario keep this as small as posible
 Going_To_Sleep();
void Going_To_Sleep(){
    sleep_enable();//Enabling sleep mode
    attachInterrupt(0, wakeUp, LOW);//attaching a interrupt to pin d2
    set_sleep_mode(SLEEP_MODE_PWR_DOWN);//Setting the sleep mode, in our case full sleep
    digitalWrite(LED_BUILTIN,LOW);//turning LED off
    time_t t;// creates temp time variable
    t=RTC.get(); //gets current time from rtc
    Serial.println("Sleep  Time: "+String(hour(t))+":"+String(minute(t))+":"+String(second(t)));//prints time stamp on serial monitor
    delay(1000); //wait a second to allow the led to be turned off before going to sleep
    sleep_cpu();//activating sleep mode
    Serial.println("just woke up!");//next line of code executed after the interrupt
    Serial.println(F("Playing LT2"));
    musicPlayer.playFullFile("/LT2.mp3"); // play the mp3
    t=RTC.get();
    Serial.println("WakeUp Time: "+String(hour(t))+":"+String(minute(t))+":"+String(second(t)));//Prints time stamp
    //Set New Alarm
  RTC.alarm(ALARM_1);
void wakeUp(){
  Serial.println("Interrupt Fired");//Print message to serial monitor
   sleep_disable();//Disable sleep mode
  detachInterrupt(0); //Removes the interrupt from pin 2;
aha - I hadn't put in the lines to initialise the music player..
