I am trying to get the Seeedstudio music shield v2.0 working and I keep getting an error when I go to upload my sketch:
MusicShield/MusicPlayer.cpp.o: In function MusicPlayer::begin()': /Users/Name/Documents/Arduino/libraries/MusicShield/MusicPlayer.cpp:148: undefined reference to Sd2Card::init(unsigned char, unsigned char)'
Hi have downloaded your library . I am not getting any error. For reference i have attached library try to save it upload it.
I have also attached example code i uploaded.
check your library. If not use below one. Please share screenshot of error message
I'm using an Arduino Uno and I am running a NRF24l01 that uses digital pins 9-gnd and the 3.3v pin.
The nrf pins are as follows:
VCC -> 3.3v
GND -> GND
CSN -> 10
CE -> 9
MUSI -> 11
SCK -> 13
MISO -> 12
Hopefully this helps.
Heres all the info on the shield...its unfortunately limited along with any support which gets me mad...
I have actually moved on to another library to try if there are any different results. Im using this library: GitHub - amperka/music-shield: Fixed Seeed Studion Music Shield library.
And my code is as follows:
// File MusicPlayer.cpp
// For more details about the product please check http://www.seeedstudio.com/depot/
// Copyright (c) 2012 seeed technology inc.
// Author: Frankie.Chu
// Version: 1.7
// Time: June 10, 2012
// Changing records:
// This library is free software; you can redistribute it and/or
// modify it under the terms of the GNU Lesser General Public
// License as published by the Free Software Foundation; either
// version 2.1 of the License, or (at your option) any later version.
// This library is distributed in the hope that it will be useful,
// but WITHOUT ANY WARRANTY; without even the implied warranty of
// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
// Lesser General Public License for more details.
// You should have received a copy of the GNU Lesser General Public
// License along with this library; if not, write to the Free Software
// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
#include <Fat16.h>
#include <Fat16Util.h>
#include <NewSPI.h>
#include <arduino.h>
#include "pins_config.h"
#include "vs10xx.h"
#include "newSDLib.h"
#include "MusicPlayer.h"
MusicPlayer myplayer;
myplayer.begin();//will initialize the hardware and set default mode to be normal.
myplayer.setPlayMode(MODE_REPEAT_ONE);//set mode to repeat to play a song
myplayer.playSong("test.wav");//play a song named with test.wav
while(1);//If the mode is normal, it will stop when it finished playing all the songs in the playlist
Ive been searching around through Seeed forums and have come across the attached library. I'm using the PlayWithInput example and am still getting an error upon initialization of the SD card. This time with the new library the error is reading
error: card.init failed
SD error: 1
I have formatted my card to FAT16 and I have one mp3 file on it titled 01.mp3. In the PlayWithInput example I changed the "name.mp3" to "01.mp3"
If theres anyone that might be able to help out i'd be so grateful! This is a huge headache lol.
Share me library itself you are working on. Initially i have shared u library have you tried out the library
Sorry but I cant locate your library... Is there any way you could reattach it?
Also I have been trying many different libraries all night with no luck. It seems that my music Shield v2 cs pin might be an issue but im not entirely sure.
I have just contacted Seeed and they supplied me with an updated library for their v2.0 model. I've attached it. It no longer gives me the "sd init" error (or at least not yet lol) but instead in serial monitor I never see anything. its as if the player.begin() function isn't loading. I've included debugging in the code and ive narrowed it down to the begin() function not working properly I believe. Hopefully this makes sense and is replicable.
