I'm trying to build the project listed here (its in Spanish)
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1277468653/
I've connected all the wires properly and used the code provided, but I seem to get weird results.
Instead of the RGB LED changing colors acoording to the analog input, I'm finding that the LED is constantly blinking in all 3 colors. The other colors are not turning off when one color is supposed to turn on at a time. Ex. Red is constantly blinking while blue and green are constantly blinking at the same time. Red is supposed to blink by itself acoording to the input of the elecret microphone.
Here's the code provided:
Bola musical luminosa
Es una bola que reacciona a la presion sonora iluminandose.
Según el nivel se ilumina secuencialmente en azul, verde y rojo.
El circuito:
* LED RGB de 4 patillas. Ánodo conectado a 5v, cátodos conectados a
pines 9,10 y 11 y luego a tierra a través de resistencias de 220 Ohm.
* Microfono preamplificado en pin analógico 0. (yo use el Breakout Board
for Electret Microphone sku: BOB-08669 de sparkfun ).
Tambien se puede utilizar cualquier elemento que nos proporcione un
voltaje variable hasta 5V.
Vídeo: http://www.youtube.com/watch?v=_QrF_CfAFEY
Mira tambien: http://www.youtube.com/watch?v=hckZEcqkg40
creado el 22 de junio de 2010
Por Alejandro Taracido Cano (TCRobotics)
Canal de youtube: http://www.youtube.com/user/TCRobotics
Musical ball light
It is a ball that reacts to the sound pressure with light.
According to the sound level it sequentially lights in blue, green and red.
The circuit:
* 4-pin RGB LED. 5v connected to anode, cathodes connected to
pin 9,10 and 11 and then to ground through 220 Ohm resistor.
* Analog microphone preamplifiers in pin 0. (I use the Breakout Board
for Electret Microphone sku: BOB-08 669 from SparkFun).
You can also use anything that will give us a variable voltage
between 5 and 0 volts.
Video: http://www.youtube.com/watch?v=_QrF_CfAFEY
See also: http://www.youtube.com/watch?v=hckZEcqkg40
created 22 Jun 2010
By Alejandro Taracido Cano (TCRobotics)
Youtube channel: http://www.youtube.com/user/TCRobotics
int MicPin = 0; // pin that the mic is attached to
int redPin = 9; // pins that the cathodes of LED are attached to
int greenPin = 10;
int bluePin = 11;
int MicValue = 0; // the Microphone value
//Serial.begin(9600); //for test the input value initialize serial
pinMode(redPin, OUTPUT);
pinMode(greenPin, OUTPUT);
pinMode(bluePin, OUTPUT);
analogWrite(redPin, 255); //turn off all LEDs
analogWrite(greenPin, 255);
analogWrite(bluePin, 255);
MicValue = analogRead(MicPin); //read the value of the microphone
//Serial.println(MicValue); //for test the input value
if (MicValue > 530) { //adjust this value to the desired sensitivity
analogWrite(bluePin,0); //lights up blue
delay(15); //small delay for quick response at low noise levels
if (MicValue > 540) { //adjust this value to the desired sensitivity
analogWrite(bluePin,255); //lights up green and turn off blue
analogWrite(greenPin, 0);
delay(60); //mid delay for response at mid noise levels
if (MicValue > 550) { //adjust this value to the desired sensitivity
analogWrite(greenPin,255); //lights up red and turn off green
analogWrite(redPin, 0);
delay(140); //high delay for response at high noise levels
analogWrite(greenPin, 255); //Turn off all LEDs
Also, the electret microphone seems to be outputting values around 500. When I talk into the microphone it doesn't seem to change much unless I actually tap the microphone (which then prints values of 0 and around 1000). Could this be the problem? I've connected AUD to analog input 0, GND to ground, and VCC to 5V.
Thanks for any help.
