/* Code by Mike4449, may or may have not been done before,I made this from scratch. It has 6 buttons, each with a different frequency, and when you push a button, the red LED will turn off and the green will turn on, then the peizo will make the
said frequency until the button is un pressed, while it is doing this, a 1602 LCD will display SOUND BOARD V1.1 and below that will be the frequency that the peizo is making.It uses 5,136 bytes of storage and 194 bytes of dynamic mem, so it is one of the bulkier
projects that ive made. Enjoy!*/
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
int button1 = 2;
int button2 = 3;
int button3 = 4;
int button4 = 5;
int button5 = 6;
int button6 = 7;
int buzzer = 8;
int led = 9; //green LED
int led2 = 10; //red LED
lcd.begin(16, 2);
lcd.print("SOUND BOARD V1.0");
lcd.setCursor(0, 1);
lcd.print("Made by Mike44449!");
delay(10000);
delay(2000);
lcd.print("Starting Up...");
delay(4000);
lcd.print("Ready!");
delay(4000);
pinMode(button1,INPUT);
pinMode(button2,INPUT);
pinMode(button3,INPUT);
pinMode(button4,INPUT);
pinMode(button5,INPUT);
pinMode(button6,INPUT);
pinMode(buzzer,OUTPUT);
pinMode(led,OUTPUT);
pinMode(led2,OUTPUT);
if (digitalRead(button1) == HIGH) {
digitalWrite(led2,LOW);
digitalWrite(led,HIGH);
tone(buzzer,440);
lcd.print("440 Hz");
if (digitalRead(button1) == LOW) {
digitalWrite(led2,HIGH);
digitalWrite(led,LOW);
noTone(buzzer);
lcd.print("SOUND IS OFF");
delay(2000);
if (digitalRead(button2) == HIGH) {
tone(buzzer,400);
lcd.print("400 Hz");
if (digitalRead(button2) == LOW) {
noTone(buzzer);
delay(2000);
if (digitalRead(button3) == HIGH) {
tone(buzzer,360);
lcd.print("360 Hz");
if (digitalRead(button3) == LOW) {
noTone(buzzer);
delay(2000);
if (digitalRead(button4) == HIGH) {
tone(buzzer,320);
lcd.print("320 Hz");
if (digitalRead(button4) == LOW) {
noTone(buzzer);
delay(2000);
if (digitalRead(button5) == HIGH) {
tone(buzzer,280);
lcd.print("280 Hz");
if (digitalRead(button5) == LOW) {
noTone(buzzer);
delay(2000);
if (digitalRead(button6) == HIGH) {
tone(buzzer,230);
lcd.print("230 Hz");
if (digitalRead(button6) == LOW) {
noTone(buzzer);
delay(2000);
else {
One of my bigger projects, the desription is in the code, you will need some LEDs and their corresponding resistors, preferable red and green LEDs, a peizo buzzer, the Uno, a PC, a cable, and a
1602 or 16x2 LCD non serialized or you will have to change the pins when you initialize the lcd library. Enjoy!
