Musizieren - Mehrere Ton Ausgaben zur selben Zeit
Moin,
ich bin vor knapp einer Woche auf folgendes Video gestoßen:
Er spielt wohl mit Hilfe der Tone Libary mehrere Tonspuren zur selben Zeit.
Bei meiner Internet Recherche bin ich auf einen Code gestoßen der immerhin zwei Spuren
zur selben Zeit ausgibt:
Kann mir jemand helfen? oder ist der Code dafür nicht geeignet?
http://www.linuxcircle.com/2014/04/17/playing-mission-impossible-tune-on-a-arduino-with-2-voices/
/*MISSION IMPOSSIBLE
Done by: André Thomas
24.01.2014
Taken out from a poker program I have written last year.
Idea for the 2-Tone same Speaker didn´t came from me.
"Mission Impossible" theme made for Arduino by me, note by note.
For compiling you need Tone() from here
http://code.google.com/p/rogue-code/wiki/ToneLibraryDocumentation
Go into the Tone Directory and change tone.cpp header (includes) to this:
#include <avr/interrupt.h>
//#include <avr/pgmspace.h>
//#include <wiring.h>
#include <Arduino.h>
so it will compile.
#include <Tone.h>
#include "frequenzen.h"
#define OUT1 7
#define OUT2 8
//Sound Vars
Tone notePlayer[2];
unsigned int Counts[] = { 0, 0};
unsigned long stopTimeNote1 = 0;
unsigned long stopTimeNote2 = 0;
int value;
int value2;
int dur;
int dur2;
//Mission Impossible // Game Finale Melodie
const int mimp[]  PROGMEM = {
NOTE_DS5,
NOTE_D5,NOTE_DS5,NOTE_D5,NOTE_DS5,NOTE_D5,NOTE_DS5,NOTE_D5,NOTE_DS5,NOTE_D5,NOTE_DS5,
NOTE_D5,NOTE_DS5,NOTE_F5,NOTE_FS5,NOTE_G5, // Upswing 5
NOTE_G2,0,NOTE_G2,0,NOTE_AS2,0,NOTE_C3,0,
NOTE_G2,0,NOTE_G2,0,NOTE_F2,0,NOTE_FS2,0,
NOTE_G2,0
,-1
const int mimpDur [] PROGMEM = {
50,50,50,50,50,50,50,50,50,50,
50,50,50,50,
50,50,50,50,50,50,
200,400,200,400,200,200,200,200,              //2000
400,-1
const int mimp2 [] PROGMEM  = {
NOTE_G3,
NOTE_G3,0,NOTE_G3,0,NOTE_AS3,0,NOTE_C4,0,
NOTE_G3,0,NOTE_G3,0,NOTE_F3,0,NOTE_FS3,0,
NOTE_AS5,0,NOTE_G5,0,NOTE_D5,0,
NOTE_AS5,0,NOTE_G5,0,NOTE_CS5,0,
NOTE_AS5,0,NOTE_G5,0,NOTE_C5,0,
NOTE_AS4,0,NOTE_C5,0,
NOTE_AS4,NOTE_G4,NOTE_FS5,0,
NOTE_AS4,NOTE_G4,NOTE_F5,0,
NOTE_AS4,NOTE_G4,NOTE_E5,0,
NOTE_DS5,NOTE_D5,0,
NOTE_AS4,NOTE_D5,NOTE_G5,NOTE_AS4,NOTE_D5,NOTE_G5,NOTE_AS4,NOTE_D5,0,
NOTE_AS4,NOTE_D5,NOTE_G5,NOTE_AS4,NOTE_D5,NOTE_G5,NOTE_AS4,NOTE_D5,0    ,
NOTE_CS5,NOTE_F5,NOTE_AS5,NOTE_CS5,NOTE_F5,NOTE_AS5,NOTE_CS5,NOTE_F5,0    ,
NOTE_DS5,NOTE_G5,NOTE_C6,NOTE_DS5,NOTE_G5,NOTE_C6,NOTE_DS5,NOTE_G5,0,
NOTE_GS4,NOTE_C5,NOTE_F5,NOTE_GS4,NOTE_C5,NOTE_F5,NOTE_GS4,NOTE_C5,0     ,
NOTE_A4,NOTE_CS5,NOTE_FS5,NOTE_A4,NOTE_CS5,NOTE_FS5,NOTE_A4,NOTE_CS5,0,
NOTE_AS4,NOTE_D5,NOTE_G5,NOTE_AS4,NOTE_D5,NOTE_G5,NOTE_AS4,NOTE_D5,0,-1
const int mimp2Dur [] PROGMEM  = {
2025,    //+25 for the delayed melody
150,50,150,50,800,800,
150,50,400,1400,
200,200,600,1000,
200,200,600,1000,
200,200,600,1000,
200,400,1400,
25,25,25,25,25,25,25,25,391,
25,25,25,25,25,25,25,25,191,
25,25,25,25,25,25,25,25,300, 0
int led = 13;   //Just a LED
pinMode(led, OUTPUT);                         // Set pinmode
notePlayer[0].begin(OUT1);                    // Voice 1
notePlayer[1].begin(OUT2);                    // Voice 2
digitalWrite(led, LOW);                       // Turn off LED
playTune(mimp, mimpDur, mimp2 , mimp2Dur ,0);  //Play the tune
void playTune(int melody[],  int melDurations[], int harmony[],  int harmDurations[], boolean repeat )
value    = pgm_read_word(&melody[Counts[0]]);
value2   = pgm_read_word(&harmony[Counts[1]]);
dur      = pgm_read_word(&melDurations[Counts[0]]);
dur2     = pgm_read_word(&harmDurations[Counts[1]]);
if(value == -1 || value2 == -1) {
notePlayer[0].stop();
notePlayer[1].stop();
digitalWrite(led, LOW); // Just a visual check if it´s doin something
if(repeat == 1) {
value=0;value2=0;dur=0;dur2=0;Counts[0]=0;Counts[1]=0;
return;
if ( millis()>stopTimeNote1 ) {
if(value==0) {
if(notePlayer[0].isPlaying()) notePlayer[0].stop();
else{
notePlayer[0].play(value);
digitalWrite(led, HIGH); // Just a visual check if it´s doin something
stopTimeNote1 = millis() + dur;
if(value != -1 ) {Counts[0]++;}
if ( millis()>stopTimeNote2 ) {
if(value2==0) { if(notePlayer[1].isPlaying()) notePlayer[1].stop();    }
else{
notePlayer[1].play(value2);
stopTimeNote2 = millis() + dur2;
if(value2 != -1 ) {Counts[1]++;}
return;
void resetTone() {
Counts[0] = 0;
Counts[1] = 0;
stopTimeNote1 = 0;
stopTimeNote2 = 0;
value=0;
value2=0;
dur=0;
dur2=0;
Mein Versuch eine weitere Spur einzubauen ist leider gescheitert.
Ich habe die playTune() Funktion um eine weitere Harmonie und Duration erweitert und die If abfragen der beiden anderen kopiert und zu einer dritten erstellt (natürlich mit hinzufügen der benötigten Variablen). Als ich dann Compelierte wurde nur dauerhaft auf allen drei Kanälen der erste Ton ausgegeben. Sobald ich aus void Setup() eine der notePlayer[0].begin(OUT1); entfernte liefen wieder zwei spuren, egal welche ausgewählt waren.
Die Antwort wird wohl mit den Ugly Details aus der von dir verlinkten Doku zusammenhängen.
Je Parallel-Ton brauchst du einen eigenen Timer, und Timer0 wird schon für millis() verwendet.
Die Erweiterung auf zwei Töne ist schon toll. Die größeren Einschränkungen (Rechteck, keine Dynamik) bleiben eh bestehen, da ist alles andere eher zweitrangig. HiFi-Stereo wirst du nicht hinkriegen...
Hallo,
ändere "Musizieren" doch bitte in "Krach-machen" :smiling_imp:
Gruß und Spaß
Andreas
Ich erwarte keine Hifi signale :smiley:
ich will nur einen kleine Bilderrahmen bauen der auch auf knopf druck etwas "krach-macht" :smiley:
gregmaster:
Und warum nimmst du dazu keinen MP3-Player, z.B. den DFPlayer-Mini.
oder MIDI-Syntisyser
