Must view hidden replies
Thread which precipitated this post: Share tips you have come across - #1161 by v205
I kept getting the reply count ball on this thread even though I'd checked it out several times.   I finally guessed that the problem was that I had not looked at a post by a user I've blocked/ignored.  After opening the hidden reply the ball notification disappeared.
So, I need to view a post by a blocked user (whose posts by definition I obviously don't want to see) to close the notification.
Sorry?
My post got hidden?
No, not yours, a different one. I just clicked on your post to have a link to go to as a reference. Sorry for the confusion.
Do you recall if the hidden post was created before or after you blocked the account?
The hidden reply is only a day old. My adding the user to the ignore list was weeks ago.
This seems like a bug. I'll beetlejuice the appropriate folks.
Thanks!
Great!
Can you send me a video via PM if it happens again? Also, open the browser's developer console with F12 to check if any specific errors are being reported.
Currently, I'm unable to replicate the issue on my test site. If an ignored user responds to one of my posts or a tracked topic, I see the bubble on the topic list and at most the banner "See X updated or new topic(s)". However, when I enter the topic and then exit, the bubble disappears even without reading the hidden replies from ignored users.
If it happens again, before clearing the bubble by opening the hidden reply, try opening an incognito window with browser extensions disabled, log in, and check if the problem still occurs that way.
OK. What's an 'incognito window' and how do I know if browser extensions are disabled?
Thanks.
Using Opera as my browser, BTW.
Incognito mode is like "private" browsing.
Generally in incognito mode the extensions are disabled by default. If you've never used it, you certainly won't have changed the behavior of the extensions either
I've hit 'open private window' many times by mistake. Didn't know it also went by incognito.
Thanks!
I'll let you know when it happens again.
