Can you quickly tell me, is it possible to mute a TV using a connected Arduino via USB?
I know it's possible using IR, but wondered; if I had an Arduino connected via USB to the TV's USB socket, can I send a command to mute and unmute the TV's volume?
Any help appreciated. Haven't been able to find a definitive answer (yet).
I'll be honest, I don't know. I'm looking to build a prototype of something that is able to mute the TV when a certain word or sound is detected.
Like I say, I know I can do it using IR, and I've seen people do a similar thing, but I want it to be able to work on any/most TV's and I believe a) most have USB ports and b) setting up IR mute/unmute has to be done on a TV by TV basis (although I might be wrong).
So, back to my original question, lets assume that the TV does allow control over USB, is it possible? And what components/shields would I need to look into.
Brains:
But what makes you think that all makes of TV will use the same protocol (assuming that they support one in the first place) over USB. I/R will be more universal and a lot easier to implement. There are only a few IR protocols used (SONY, NEC etc) so DIP switches to select model type might work okay.
The USB on the digital TV is for memory stick or hard drive to play recorded movies and programs.
I have a PVR that has a USB for firmware/software update but not control.
