Mutiple HX711 to measure three different load cells
Hi!
Im working on a project where i have to measure three different weights, as three different inputs.
I'm using 3 three load cells, each hooked up to their individual HX711 amplifier.
My problem is that i dont know how to do this, and i can't seem to find any information on my specific problem. I can make each work alone, but i need a way to measure the current weight on all three load cells through my loop.
I'm using Bogde's HX711 library: GitHub - bogde/HX711: An Arduino library to interface the Avia Semiconductor HX711 24-Bit Analog-to-Digital Converter (ADC) for Weight Scales.
My current code looks like this:
#include "HX711.h"
#define calibration_factor -750.0 //This value is obtained using the SparkFun_HX711_Calibration sketch
 int DOUT = A8;
 int CLK = A9 ;
HX711 scale(DOUT, CLK);
  Serial.println("HX711 scale demo");
  scale.set_scale(calibration_factor); //This value is obtained by using the SparkFun_HX711_Calibration sketch
  scale.tare();	//Assuming there is no weight on the scale at start up, reset the scale to 0
  Serial.println("Readings:");
  Serial.print("Reading: ");
  Serial.print(weight, 1); //scale.get_units() returns a float
  Serial.print(" G"); //You can change this to kg but you'll need to refactor the calibration_factor
Hello,
I have been following this thread here:
These guys have been through this recently.
