mutli-key keypad and modifier keys
newb here, I cant seem to get modifier or function keys to work inside of a multi-key keypad (using a teensy 3.0), any advice/ solutions?
here is what i have so far
#include <Keypad.h>
const byte ROWS = 4;
const byte COLS = 3;
char keys[ROWS][COLS] = {
  {'1','2',MODIFIERKEY_CTRL},
  {'4','5','6'},
  {'7','8','9'},
  {'*','0','#'}
byte rowPins[ROWS] = {4, 3, 2, 1};
byte colPins[COLS] = {18, 17, 16};
Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
Keyboard.begin();
  kpd.setDebounceTime(1);
  if (kpd.getKeys())
    for (int i=0; i<LIST_MAX; i++)   // Scan the entire list.
      if (kpd.key[i].kchar != NO_KEY)    // Test for an active key.
        switch (kpd.key[i].kstate) {
        case PRESSED:
          Keyboard.press(kpd.key[i].kchar);
          if (!kpd.key[i].stateChanged)
          case RELEASED:
            Keyboard.release(kpd.key[i].kchar);
Where do you try?
String msg = "";
Why?
,< corrected the code on the op to represent what i am using better, a few things are not in there now.
  {'4','5','6'},
  {'7','8','9'},
  {'*','0','#'}
MODIFIERKEY_CTRL is not working in the matrix any printable character work fine but none printable characters such as F1 or PgUP ect. dont seem to work
Durz_o:
#include <Keypad.h>
 {‘1’,‘2’,MODIFIERKEY_CTRL},
 {‘4’,‘5’,‘6’},
 {‘7’,‘8’,‘9’},
 {’*’,‘0’,’#’}
Keyboard.begin();
 if (kpd.getKeys())
        case PRESSED:
You need a break; statement here.
          case RELEASED:
You may need a default:
break; here to trap any odd events.
Where are you using MODIFIERKEY_CTRL to modify the output?
